1990 F350
Old May 24, 2016 | 12:26 PM
dybeepvw's Avatar
dybeepvw
1990 F350
Help; 1990 F350 4x4 single cab lariat, 7.5L, auto tranny. Lately more and more when starting the truck up cold I have to have my foot pressed slightly on accelerator pedal and keep it revved up for about a minute to run on its own. It used to just automatically start up and run at 1100 rpm for about a minute without using the pedal. No CEL's come up so I am wondering if a sensor is acting up like TPS or Idle air control. Any suggestions on this if someone else has had this happen, I changed cap, rotor,wires, plugs, air filter, fuel filter . Thanks
Old May 24, 2016 | 01:42 PM
johnvirgil's Avatar
johnvirgil
Sounds like the Idle air control valve to me. Its fairly common and easy to replace. Don't try adjusting the throttle stop screw though. That is preset from the factory and the computer controls the idle anyway.
Old May 24, 2016 | 05:43 PM
4DB's Avatar
4DB
Second. That's an IAC responsibility.
Old May 24, 2016 | 08:42 PM
Lead Head's Avatar
Lead Head
Even though the CEL is not set, have you tried pulling the codes? For example, a bad coolant temperature sensor could cause what you describe.
Old May 25, 2016 | 08:52 AM
dybeepvw's Avatar
dybeepvw
Thanks, I will check the codes with my reader anyway. Have another issue that came up yesterday on tranny shifting up at higher rpm and torque converter not locking up; guessing that is sensor also.
Old May 25, 2016 | 03:09 PM
The_Drew's Avatar
The_Drew
This sounds like a bad tps to me
Throttle position sensor
Jade Peterson
May 22, 2017 01:36 PM
2014fordfan
Aug 13, 2012 11:07 AM
Mike V
Jul 12, 2010 10:23 PM
Bryan Whited
Nov 28, 2002 02:25 PM
geoford
Sep 5, 2000 03:23 PM
