Sponsored by: Real Truck
wont idle
Old May 16, 2017 | 04:02 PM
Jade Peterson's Avatar
Jade Peterson
wont idle
2003 f350 2wd 5.4 auto cab and chassis with 40 gal rear tank
replaced fuel pump/fuel filter/spark plugs/IAC
no codes
cant seem to upload video file
Old May 16, 2017 | 08:50 PM
StrokinIT2001's Avatar
StrokinIT2001
That's a tough one with no codes.. check your air intake system mass air flow maybe... maybe check vacuum?? Hard to tell
Old May 17, 2017 | 08:56 AM
alloro's Avatar
alloro
Won't idle as in it stalls right after starting or when coming to a stop?
Does it drive okay once you're moving with your foot on the gas pedal?
Old May 22, 2017 | 09:52 AM
Jade Peterson
wont idle
yeah, stalls after starting only runs if I feather the throttle around 2000rpm and better
Old May 22, 2017 | 10:36 AM
redford's Avatar
redford
FTE Leadership Emeritus
Sounds like you still might have an IAC issue.
Old May 22, 2017 | 11:18 AM
alloro's Avatar
alloro
Starting to sound like the MAF sensor is dirty or no good.
Old May 22, 2017 | 11:38 AM
Jade Peterson
wont idle
diving in on the IAC again
no codes for map
checking for vac leaks
will keep posted
Old May 22, 2017 | 01:36 PM
redford's Avatar
redford
Let us know what you find.
Jade Peterson
May 22, 2017 01:54 PM
Bftford
Feb 5, 2014 02:59 PM
StealthWyvern
34
Mar 8, 2009 10:24 AM
Aggie05
1983 - 2012 Ranger & B-Series
May 28, 2008 05:50 PM
ardundave
Aerostar
Jan 1, 2006 08:22 PM
