Run 400 without valve covers
Old May 22, 2016 | 06:58 PM
Ford_Six's Avatar
Ford_Six
I am tracking down a hot misfire on my 400 that may be a sticking valve (accompanied by a lifter tick about in time with the misfire), so I need to check valve operation. However, this only happens once the engine has been loaded and worked a bit, so I need to run it a while open.
Do the 400s tend to gush oil all over without the covers or do they keep it in the heads? This is in a van so sprayed oil would be in the interior of the truck.
Old May 23, 2016 | 07:41 AM
Gary Lewis's Avatar
Gary Lewis
I don't know, but I'm subscribing to see what others say. My guess is that Tim Meyer would know.
Old May 23, 2016 | 12:33 PM
mjr46's Avatar
mjr46
I cut the tops off of some 302 valve covers one time when adjusting the valves while it was running...old school way...lol, didn't spray to much oil but with no valve covers the problem is the oil draining back down often builds up and runs over the rail, that hitting the manifold/header will make a smoke train!!!
Old May 25, 2016 | 09:50 AM
beartracks's Avatar
beartracks
Ditto............
Old May 26, 2016 | 06:31 AM
mark a.'s Avatar
mark a.
Yes, oil is going to go everywhere.
Old May 27, 2016 | 11:56 AM
hollenjoe's Avatar
hollenjoe
yep its messy
Old Jun 6, 2016 | 10:12 AM
Filthy Beast's Avatar
Filthy Beast
I also cut off the top part of some after market (junk, BTW) valve covers - at the top 4 bolt holes. I then welded the top onto the bottom, making it higher. I had to beat the top part a bit to make it conform to the bottom. I then scuffed the gasket side of the v/c, put some black RTV on it and attached the rubber gasket to it so it would stay on after repeated use.
They worked well until I goosed it a bit - I have roller rockers - they spewed some oil out, but not too bad. I think the oem stamped steel rockers would work better - they have the little oil guard on the bolts.
1994Toyota
16
Jun 22, 2018 05:10 PM
1FastGambler
Aug 28, 2013 02:06 AM
300ForMe
Sep 7, 2008 05:19 PM
400Monster
Mar 10, 2006 03:55 PM
dbarracuda
Apr 18, 2003 10:00 AM
