400 valve tick
Old Mar 9, 2006 | 10:06 AM
400Monster's Avatar
400Monster
400 valve tick
hey all, have a 79 400 with 650cfm edlebrock carb and intake.....have 129000 on the motor and it was rebuilt at 113000.......after i replaced the valve covers i noticed a tick coming from the drivers side of the motor....Took the one off and i couldn't see anything wrong at all, it was fine before i replaced them now its just annoying me haha.....any suggestions would be awsome...im stumped..change oil every 1700 to 2000 miles...
Old Mar 9, 2006 | 07:27 PM
danlee's Avatar
danlee
Did you check your valve lash?
Old Mar 9, 2006 | 11:06 PM
Torque1st's Avatar
Torque1st
Posting Legend
Clarification please: Are you saying it was OK b4 you replaced the valve covers and then after you replaced the valve covers it is making a noise? Did you replace the valve covers with a different type not just remove and replace the same valve covers? Did you use the same size and type of valve cover gaskets?
Old Mar 10, 2006 | 09:58 AM
400Monster's Avatar
400Monster
Yea the valve covers were from a 351M so they fit right up.....There was no noise BEFORE i changed them, but after i started it up there just was a little bit of a tick that wasn't there before......Valve lashes look alright, i mean it could just be time to change the valvetrain and whatnot.....kept lookin for a problem i just dont see anything wrong.....everythin is torqued down to spec so im stumped.....
Old Mar 10, 2006 | 10:11 AM
danlee's Avatar
danlee
Put the old cover on the side with the tick, see if it goes away.
If not run it without a cover, use a screw driver to push on the rockers one at a time, see which valve is making the noise.
Old Mar 10, 2006 | 11:51 AM
beartracks's Avatar
beartracks
Sounds like the oil baffle rubbing on a rocker.
Old Mar 10, 2006 | 03:55 PM
400Monster's Avatar
400Monster
well one thing led to another and i ended up pulling the whole motor out and junkin the truck, got the whole topend apart, just going to replace it, everything looked fine when it was sittin in the motor....being out and on a bench is another story, had 2 springs that broke when i took them off, and a cracked bolt......wasn't expecting it but now i know why it was ticking....it will be awhile befoe the ole 400 will be running again...no money to fix it.....thanx for the advice!
thedopefishlives
Sep 10, 2016 02:06 PM
1978fordxltranger
Jun 30, 2014 01:59 PM
400inatruck
17
Jul 27, 2012 08:04 PM
cadetspider06
Jun 3, 2011 08:04 AM
lowrider57
May 26, 2010 09:55 PM
