Advice on dead engine
Old May 27, 2016 | 09:57 PM
Aune163rd's Avatar
Aune163rd
https://www.google.com/search?q=6.0+...0704425&spud=0
Old May 28, 2016 | 10:00 PM
m-chan68's Avatar
m-chan68
Which dealer is doing the work if you don't mind me asking? I see that you are from Ontario.
Old May 28, 2016 | 10:09 PM
Lawrencew's Avatar
Lawrencew
I'm actually from manitoba, I have two choices , my truck is curently at a private shop. Reading the fine print on new engine warranty it seems the work must be completed by the dealer so I'll have to decide soon
Old May 29, 2016 | 09:59 AM
freejay's Avatar
freejay
There's a reason so many companies specialize in Cummins swaps. You could probably do it for half of that...
Old May 29, 2016 | 12:23 PM
Lawrencew's Avatar
Lawrencew
From what I see a reman cummins will cost the same or touch more R and R is similar , few more items with cummins. If it's that close I'll stick with the ford engine ! It provided 350,000 km trouble free, and I'd hate to guess the idle hours spent in the oil patch
Old May 29, 2016 | 05:43 PM
Yahiko's Avatar
Yahiko
Maybe because it a cash cow. Then try to sell the truck after. You will
never see the $ you put into it. Also getting service for it will be a
cash cow for the one that takes it on. That is IF you can find a mechanic
that will touch it at all.
I would be willing to bet that when they have a significant issue then end
up sitting in the back 40 rusting to death or under the blackberry bush.
Sean <BR>
6.0L Tech Folder
Old May 29, 2016 | 05:44 PM
m-chan68's Avatar
m-chan68
Reasons that I, and many others others don't understand. The OP already stated he's not crazy about a Cummins engine, and quite frankly neither am I. I'm sure they have their own sets of issues. If we're going to compare apples to apples, I am quite certain he will be dollars ahead swapping out a Ford reman engine into his truck, versus a reman Cummins in and then have to deal with the cost of fabrication to make it work, resulting in an end product serviceable only by the shop that did the swap.
Old May 29, 2016 | 06:05 PM
Lawrencew's Avatar
Lawrencew
I could not have said it better! For curiosity I did price a reman cummins from my local peterbuilt ; $17000. Also priced an in frame re build on my 3406E cat to make me feel better;$46,000
Old May 29, 2016 | 08:47 PM
m-chan68's Avatar
m-chan68
Just for the prices of those engines alone, you could buy yourself a decent newer truck.
Old May 29, 2016 | 08:57 PM
BLADE35's Avatar
BLADE35
this is for a 2003 short block auto nation
pretty good price idk what you after
N/A 3C3Z-6009-AARM 3C3Z-6009-AARM / SHORT BLOCK1 F350
$5,089.66
Old May 29, 2016 | 09:04 PM
Lawrencew's Avatar
Lawrencew
Thought about IT , buy a 10 yr old truck with 200000km on it for $20000 and what if Ya get a surprise in few months or even couple yrs? Then I'd have two parked in trees . Short block price is attractive but after further exam my turbo and injectors are tired too. Going to contact dealer in morning have a chat
Old May 29, 2016 | 09:09 PM
m-chan68's Avatar
m-chan68
Most dealers are pretty open to a break on the labour rate as well as the mark up on the price of the parts on a repair like this, if there is any kind of inkling that you are thinking of going ahead with this. From a dealer tech himself, the only factor making this worthwhile on a 13 year old vehicle with that kind of mileage, is the known history of it and the fact it is a manual transmission truck which is very hard to come by these days.
Old May 29, 2016 | 10:36 PM
  #28
Lawrencew's Avatar
Lawrencew
I appreciate that , yup Trans and clutch both good , did brakes year ago , I built the deck and shortened the frame myself , overkill on both. Front fenders been rrplaced . I'll give them a raking over 😏
Old Jun 9, 2016 | 08:06 PM
  #29
Lawrencew's Avatar
Lawrencew
So I found an 06 F550 with a manual 6spd same as my 03. Question is will that setup work in my truck
Old Jun 9, 2016 | 09:09 PM
  #30
TooManyToys.'s Avatar
TooManyToys.
When I investigated this years ago the only thing I found that was needed was to extend the ICP sensor harness so it would it to the newer engine location. Exhaust back pressure too depending on what you want to flip. The rest of the '03 harness was fine. Now I never did the swap so I can't confirm. Mechanically everything should bolt up.
But I'd be much more comfortable hearing from one of the guys that flip these weekly.
