back to the low beam problem
Old May 21, 2016 | 10:22 PM
4x4man514's Avatar
4x4man514
hey guys, I know this question has been asked many times but I cant seem to find the answer I need. most answers come back on newer model trucks and don't pertain to my 86 f150.
my high beams are working fine but I have no low beams. a lot of people say the bulbs are bad about going bad at the same time but I have all brand new bulbs and harness. im running the lmc clear lights, euro I think they are called. and I upgraded to their harness with the relays as well. ive checked 3 fusable links near my solenoid ( im not sure which one is right) but they are all showing good. ive checked my dimmer switch and in one position I have 2 hots and a dead, and in the other position I have 2 hots and a dead, with the dead alternating between positions. it seems like it should work that way.
one weird thing ive found and im thinking it may be unrelated ,because from what I understand there are no headlight fuses, is that not all my fuses have power. some do some don't. I thought if the fuse box had power then all fuses would have power.
otherwise im at a loss. can anyone think of anything I have missed?
thanks a bunch guys!
Old May 21, 2016 | 10:38 PM
FuzzFace2's Avatar
FuzzFace2
So if I have this right it sounds like the dimmer switch is working right and sending power out to the bulbs both high & low beams.
If I also have this right you have LMC relay kit. I would check to make sure you have power to the factory plugs for hi/low beams and go from there.
Dave ----
Old May 22, 2016 | 02:39 AM
4x4man514's Avatar
4x4man514
yea that's kind of what I was thinking, that plug did feel a little loose I guess the high beam connector may be making contact but the low beam connector isn't. guess I got to take those batteries out AGAIN.
thanks
kevin
Old May 22, 2016 | 06:37 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Try swapping relays in your headlight harness.
I had one burn out, and the lowbeam obviously gets a lot more use.
LMC does sell spares.
Old May 22, 2016 | 02:27 PM
4x4man514's Avatar
4x4man514
They do sell spares.
That's true. That will be easy too.
Thanks
Old May 22, 2016 | 02:33 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I have an old Hella dual relay mounting block and have considered swapping over for the availabilty of 'Bosch cube' type relays.
Now that my A.I.R. pump inlet filter/muffler is gone there is room to revisit the idea.
Old May 27, 2016 | 08:05 PM
4x4man514's Avatar
4x4man514
Problem solved! It turned out one of the prongs in the factory harness had backed out when I plugged it in. All lights in good working order. Project complete!
Thanks for all you're help guys!
mechasus
Escape & Escape Hybrid
Oct 25, 2021 04:06 PM
DeadFife
Apr 28, 2017 07:12 PM
Nitrous
Nov 20, 2014 06:56 AM
PwerStroke99
34
Nov 3, 2009 11:12 AM
speed
Electrical Systems/Wiring
Mar 4, 2009 06:16 PM
