Stuck in 4wd?
Old May 21, 2016 | 05:50 PM
Wrecklesswisdom's Avatar
Wrecklesswisdom
Stuck in 4wd?
My 72 f100 seems to be stuck in 4wd. The front lockers won't turn and it won't shift our of 4wd. Halp?
Old May 21, 2016 | 06:23 PM
RichS2659's Avatar
RichS2659
You probably have axle wrap-up. Are you on pavement now? Find a patch of dirt, and hit the throttle to let the axles unbind. Being on dirt lets the axles relieve the stress of turning at different speeds. It is common thing that happens.
Old May 21, 2016 | 08:58 PM
Wrecklesswisdom
This explains alot. I pulled the shaft cuz I had to get moving, but it's good to know that nothing is probably broken. Thank you so much.
That Being said, I Definitely Blew A Rear Brake Line Haha. So I'll be fixing that tomorrow
Old May 23, 2016 | 09:10 AM
orich's Avatar
orich
I Shift the 4wd lever into N or 2wd at about 2-3 mph just coming to a stop is what, I've always done.
Also putting it into reverse should relieve the binding pressure just a bit helps.
Orich
WhySoSerious
17
Oct 5, 2014 08:26 PM
1997f1504X4,4.6L
1997 - 2003 F150
Aug 24, 2010 09:08 PM
tholt34
13
Jul 24, 2008 09:16 PM
mcvcpa
Dec 3, 2005 03:08 PM
riksco
Bronco II
Nov 29, 2004 09:34 PM
