352 with new heads overheating
Unlike SBFs, dunno of issues with head gasket orientation.
Tolerances too tight? Timing verified as accurate?
Stuck/bad thermostat? Did ya drill a 1/8-inch hole on the t-Stat flange to bleed odd trapped air? Is the t-Stat facing the right way?
Btw, is it truly boiling over or are you relying on the notoriously inaccurate OEM temp gauge?
I will do my best to explain this in the little time I have before I leave for work. The FE heads have open water ports on both sides of the head. This allows the heads to be inter changed and not specific to one side of the block so to say. This means when you put the gaskets on the heads, there should be a side blocking the water ports on one side. (Cannot remember off the top of my head but I'm sure a quick search would help.) You need to make sure you have appropriate gaskets and are blocking the correct water ports of each side of the head. I ran into this exact same issue as you a while back and it drove me crazy for a good 2-3 weeks. If I happen to remember when I get home from work I will send you a link regarding the correct information. Many guys see there gaskets are going to block one of the water ports and think it is an issue with the gasket, they proceed to cut open the other water port and then get confused as to why there engine is overheating despite having all the water ports cut open. (What happened in my situation, except that mistake was done by a machine shop that flips used engines.)
It sounds like the head gaskets are in backwards. You can tell by looking at the exposed edge of the head gasket if it is back to front. Sorry I can't send you a pic but if you look at another FE with the gaskets installed correctly you will see what I mean. If yours look the same, the heads can stay on. If they look different, then...
on
Orich
