Sponsored by: Real Truck
Speedo synchronized with new differentials
Old May 21, 2016 | 03:38 PM
klr650goldwing's Avatar
klr650goldwing
I recently changed the differentials in a 04 super duty from 3.73 stock to 4.56. What do I need to do to make the speedometer read correctly?
Old May 21, 2016 | 06:46 PM
WE3ZS's Avatar
WE3ZS
You don't need to do anything, unless you also changed the tire size. The tone ring for the speed sensor pickup is mounted to the ring gear so it is turning at the same RPM as the axle/tire. So a gear change won't alter the speedo reading but a tire size change will, I've done both to my rig and my speedo remained at the factory inaccurate reading with my change from 3.73 to 4.88. But when I upgraded tires from 32" to 35" that knocked my displayed speed down below the actual speed.
Old May 22, 2016 | 04:09 AM
klr650goldwing
The reason I asked is that today I drove by an electronic speed sign and it indicated my speed was 5mph slower than my speedometer indicated. It wasn't like that before the differential change.
Old May 22, 2016 | 06:39 AM
Bigdon68's Avatar
Bigdon68
Use your GPS.
Old May 22, 2016 | 06:40 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Changing the differentials does not affect the speedometer. How do you know that sign was accurate?
Old May 23, 2016 | 10:16 AM
klr650goldwing
Well when I drive by the same sign in my car the speedo in the car and the sign agree with each other.
But if you all say that changing the differentials does not alter the speedometer or odometer than I guess all my questions are moot.
Old May 23, 2016 | 10:41 AM
Mark Kovalsky
You can correct the speedo reading, but changing the diff ratio didn't cause it to be wrong. It takes a high end scan tool that can communicate with the computer. There is a parameter to adjust the speedo reading.
Kai Herrmann
Jul 26, 2019 02:10 PM
metru
Nov 8, 2017 09:26 PM
jpjahn
62
Jan 17, 2006 11:26 AM
75Player
2004 - 2008 F150
May 16, 2005 01:47 PM
rbtnt
Nov 19, 2003 06:21 AM
