I like 3M, but any of the higher end professional body shop stuff sold at your local auto paint supplier, is good. As Jules says don't use anything from your local hardware store or big box DIY store made for sealing tubs and windows. SEM is also a good brand and has several different products depending on where you plan to use it.
I would put some good rust proofing primer in that seam before sealer. They make DTM(direct to metal) seam sealers, but I personally don't care for them.....I doubt they provide any corrosion resistance.
I use 3M 0308 exclusively for sealing seams. A little pricey but for as often as you use it, it is well worth the price knowing that it is doing the job. This sealer is also excellent for filling the drip rail trough...super bond and never shrinks or decomposes like the OEM sealer.
I sanded the seam as best i could, then sprayed it with rustoleum rust reformer. Then I was going to apply the sealer.
So I should prime it first, then the sealer?
My plan is to put a couple more coats of epoxy primer on the cab. Do you think it would be ok if I spray some Rustoleum rattle can primer, seal the seam, then the epoxy primer?
Reason: .
The seams on these trucks are notoriously "leaky". Here is a pic of my 56 after I applied KBS Rust Seal along the trough on the inside of the roof seam. As you can see, the sealer oozed through the gap in the seam. The Rust Seal product is a rust-encapsulator...I believe that I have a better repair now than I could have with a seam sealer or a spray on product. Good luck...
Personally, I like as much protection as I can get under the sealer. Once the sealer is on, whatever is underneath is trapped there. If the seam is clean, a good primer(like epoxy) is fine.....if rusty, do like Charlie says and use a rust converter or similar first, then prime.
I normally prime with epoxy, seal the seams, then prime with high build or primer/sealer.
