Testing Brake Switch Circuit
Old May 21, 2016 | 10:40 AM
GuitarJesus's Avatar
GuitarJesus
On Project Cobalt the previous owner messed with the brake switch a bit. Which wire is the hot lead coming in so I can test for proper circuit?
The green with red/pink, or the solid green? It needs a new pigtail, it looks like it was halfway melted at some point. So I'll probably go to the JY and grab a pigtail from a donor truck to rewire it.
Old May 21, 2016 | 06:10 PM
88_F0RD's Avatar
88_F0RD
how many wires?
if its just two, I would think you could find the hot wire with a test light.
ground the test light, probe the wire(s).
the test light should glow on the hot wire,
if it doesn't glow on either wire, try pressing the brake pedal down, and see if the test light glows probing the wire(s)
which ever wire glows is the hot wire; the other is a ground wire.
Old May 21, 2016 | 06:22 PM
GuitarJesus
Originally Posted by 88_F0RD
how many wires?
It's the standard two. I'm away from home on a family outing for the day. I just wasn't sure if it's a hot 12v, or a ground that is an open circuit where I'd be testing for continuity
Robocop2269
Apr 17, 2018 11:56 PM
72Blazerod
Aug 7, 2013 04:32 PM
hugger94
Jun 16, 2009 08:13 PM
Glockem45
All Things Towing
Dec 31, 2008 01:56 PM
UnderTakr
Modular V10 (6.8l)
Nov 17, 2004 06:00 AM
