So the v8 is in. Trans is in. Now it won't shift in drive because the Speedo doesn't work. Does anyone know where the speed control is in a 92 bronco? Is it in the transfer case or is it in the rear axel?
Speed-sensor is mounted on the top of the rear axle housing.
