Transfer case upgrade
Old Nov 29, 2005 | 07:47 PM
baily034's Avatar
baily034
I have a 75 Ford F150 300 6cyl, 4 speed standard trans with a one speed transfer case. I have a 205 from a 77 automatic C6 trans that I would like to swap onto the standard trans. Does anyone know what parts I will need to make the swap.
Thanks.
Old Nov 29, 2005 | 08:29 PM
User 71024's Avatar
User 71024
Thanks.
are you sure of that, I don't think I've ever seen a one speed transfer case?
Old Nov 29, 2005 | 08:31 PM
MBBFord's Avatar
MBBFord
From 73-79 there were only 2 options of transfer cases and both had 2 speeds, one was a NP205 part time t case, and the other was a NP203 full time t case.
Old Nov 29, 2005 | 08:41 PM
deisele75's Avatar
deisele75
It's probably being stubborn and will not go into 4low
Old Nov 29, 2005 | 08:45 PM
oldhalftons's Avatar
oldhalftons
some 73-74 F100s had a single speeds transfercases
Old Nov 29, 2005 | 09:25 PM
baily034's Avatar
baily034
Just went and rechecked the tc I want to put in the 75 Ford and it is a NP 203. Sorry about any confusion.
Old Nov 29, 2005 | 09:30 PM
MBBFord's Avatar
MBBFord
Actually I'm having a similar problem, and I'm pretty sure it's only the linkage. Not sure how to fix it, but I know if I go under the truck and switch it into 4wd then the t case works great.
Old Nov 29, 2005 | 10:06 PM
baily034's Avatar
baily034
The tc in the truck now is a single speed. Only 2w high and 4w high, no low at all, that is why I am wondering if the NP203 would go in and what parts would be needed.
Old Nov 29, 2005 | 11:31 PM
MBBFord's Avatar
MBBFord
Ok, you'd need a adapter from a standard tranny that came off of a NP203 also. Then you might need a 203 crossmember, and driveshafts.
Old Nov 30, 2005 | 12:05 AM
baily034's Avatar
baily034
I have the 203 driveshaft from the automatic. The frame has the crossmember in place. The 75 has the driver side mount for the 203. Is there a spline shaft that goes from the output shaft of the transmission to the input shaft of the tc. Thanks for all your help.
Old Nov 30, 2005 | 07:09 AM
User 71024's Avatar
User 71024
Do you have the model # of the one speed?
MBBFord's Avatar
MBBFord
Yes there is. The adapter between the tranny and t case are all different, whether they are manual or auto, 203 or 205.
Old Nov 30, 2005 | 09:16 AM
oldhalftons
Its a dana-21, used from 69-74 F100's, not just 73-74
Old Nov 30, 2005 | 10:13 AM
User 71024's Avatar
User 71024
That must have been a penny pinching move by ford, I've never seen one in my life on anything, hell even the crapbox bronco 2 my wife had was a 2 speed.
Old Nov 30, 2005 | 10:56 AM
77300i6's Avatar
77300i6
A lot of OEMs used a single speed T-case in those days. Not too many people really had the need for a low range.
