ac problem
Old Apr 11, 2004 | 08:21 PM
puckee's Avatar
puckee
Question ac problem
compressor clutch does not engauge
help
Old Apr 11, 2004 | 09:20 PM
LoosMaster's Avatar
LoosMaster
Have you had your system pressure checked? Could be low.
Old Apr 11, 2004 | 09:56 PM
puckee's Avatar
puckee
Question
ok i changed the compressor and the gas released when I removed the manifold on the back, I purchased a kit to replace the gas but The compressor does not run..checked the fuse and all do I need to charge the system and then turn the compressor on??
Tom
Old Apr 11, 2004 | 10:00 PM
LoosMaster's Avatar
LoosMaster
You have to put the freon in, with the system on. When it reaches the proper level the compressor will kick on unless you have other issues with the system.
Old Apr 11, 2004 | 10:01 PM
puckee's Avatar
puckee
thanks i will go try it
Old Apr 11, 2004 | 10:43 PM
puckee's Avatar
puckee
worked thanks
Tom
