So my fan speed sensor popped up on Torque. I almost never hear the engine fan in the first place. But once in a while I do. I've only ever heard it when I'm laden with enough weight to really strain the engine. It sounds like a freight train when it does kick on. Should I be worried? I've done the EGR delete. New oil cooler. 4" straight pipe from turbo to just behind the cab. 130k on the works. 6spd manual.
Holy crap. I've had my egr valve unplugged for over a year now. The shop that deleted my egr valve and cooler said I didn't need it. The kit he got came with a pipe for the redirect. And a block off plate.
remove the Plate and install it in manifold then plug it in OR some just plug in and Lay it in there without bolting it in the intake manifold
It Fools the PCM
Iv got the same style EGR Deleate as you just my EGR valve is installed in manifold and plugged in because its Cleaner look and I didn't want it bouncing around
No. My dash cluster was replaced and wasn't programed. Just as built data from ford. My speedometer reads 5 mph fast. And the 4x4 light don't come on. Nor does the CEL.
