Sponsored by: Real Truck
sync help
Old May 19, 2016 | 06:07 AM
1turbo6's Avatar
1turbo6
sync help
Hey guys, i just picked up a 2013 F-350 with the base sync and cannot get it to do anything. when I press the phone button nothing happens. I tried to unhook the batteries for a couple minutes but that didnt seem to make a difference. altho the radio did maintain the preset memory, so maybe it wasnt long enough. I called Ford sync help line and they said unhooking the batteries does nothing. any ideas?
Old May 19, 2016 | 06:13 AM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to TE, 1turbo6.
Do you have an owners manual?
Old May 19, 2016 | 06:16 AM
1turbo6's Avatar
1turbo6
yes, doesnt say much. did I miss something?
Old May 19, 2016 | 06:30 AM
redford's Avatar
redford
I guess so, since it isn't working. (I know, thank you Captain Obvious)
But, pages 421-464 are just for the Sync system, so I wouldn't say it doesn't say much.
There are a lot of moving parts to the system, and way too many variables to comment on, given the symptoms you are seeing (it doesn't work).
I'd start with the troubleshooting charts on page 460 or so, then contact the Ford Sync team at the provided number if you are unable to make it work.
We also have a dedicated forum for "in vehicle systems" like Sync. You might try there. https://www.ford-trucks.com/forums/forum275/
Old May 19, 2016 | 06:32 AM
1turbo6's Avatar
1turbo6
I called ford sync team and they said since the phone button doesnt work/respond I cant reset the system. ill take another look at the book.
Old May 19, 2016 | 06:36 AM
Crispy71's Avatar
Crispy71
You can check the fuse in the passenger footwell also.
Old May 19, 2016 | 06:37 AM
1turbo6's Avatar
1turbo6
checked it, it's good.
Old May 19, 2016 | 06:39 AM
redford's Avatar
redford
Since it is a used truck, I'd start with the section that restores the system to the factory default settings.
Old May 19, 2016 | 06:54 AM
1turbo6's Avatar
1turbo6
Cant reset when I press the Aux button it only goes to sat radio. not sync, so I cant perform the Master reset procedure.
Old May 19, 2016 | 07:07 AM
Crispy71's Avatar
Crispy71
Do you have the USB port and does it work if you use it?
Old May 19, 2016 | 07:09 AM
1turbo6's Avatar
1turbo6
I have one but havent tried to use it. I did plug my phone cord into it once thinking it would charge my phone but it didnt.
Old May 19, 2016 | 07:15 AM
Crispy71's Avatar
Crispy71
It should have. This is leading me to think that someone did some sort of mod on the truck and then tried to undo it when they sold it. You might need to dive behind the dash to find out. Fastest way to check if you still have your sync module installed is to open the passenger door and pull the side dash panel. Sync module should be behind it.
Old May 19, 2016 | 07:23 AM
1turbo6's Avatar
1turbo6
I was thinking the same thing, great idea. possibly had aftermarket system and half assed back to stock.
Old May 19, 2016 | 12:45 PM
FordIVTteam's Avatar
FordIVTteam
Official Ford Rep
Hi 1turbo6,
I recommend performing a key cycle since the Phone button is inoperable. To do so: Turn the vehicle off > Remove the key > Open the driver's side door > Lock the door (either from key fob or door lock button) > Close the door > Wait 2 minutes > Start the vehicle. If the key cycle does not fix the Phone button, then you'll need to take the truck to the dealer for a more hands on approach.
Cara
Old May 19, 2016 | 01:11 PM
1turbo6's Avatar
1turbo6
thanks I'll give it a try.
