Hey guys, i just picked up a 2013 F-350 with the base sync and cannot get it to do anything. when I press the phone button nothing happens. I tried to unhook the batteries for a couple minutes but that didnt seem to make a difference. altho the radio did maintain the preset memory, so maybe it wasnt long enough. I called Ford sync help line and they said unhooking the batteries does nothing. any ideas?
It should have. This is leading me to think that someone did some sort of mod on the truck and then tried to undo it when they sold it. You might need to dive behind the dash to find out. Fastest way to check if you still have your sync module installed is to open the passenger door and pull the side dash panel. Sync module should be behind it.
I was thinking the same thing, great idea. possibly had aftermarket system and half assed back to stock.
Hi 1turbo6,
I recommend performing a key cycle since the Phone button is inoperable. To do so: Turn the vehicle off > Remove the key > Open the driver's side door > Lock the door (either from key fob or door lock button) > Close the door > Wait 2 minutes > Start the vehicle. If the key cycle does not fix the Phone button, then you'll need to take the truck to the dealer for a more hands on approach.
