Sponsored by: Real Truck
sync help
Old May 19, 2016 | 01:12 PM
1turbo6's Avatar
1turbo6
ford dealer service Manager suggested try to unhook batteries for at least 20 min.
Old May 19, 2016 | 01:24 PM
1turbo6's Avatar
1turbo6
Key cycle didnt seem to have an effect. I'll try to unhook batteries again, then i give up.
Old May 19, 2016 | 01:44 PM
jonrjen's Avatar
jonrjen
Go online to the Ford site and register your VIN. I know on my 2013 there is a warranty extension on the radio due to a known issue with communication. See if this doesn't apply to your vehicle and then contact a local Ford dealership and discuss the problem to see if it wouldn't be covered under this warranty extension.
Old May 19, 2016 | 02:31 PM
1turbo6's Avatar
1turbo6
Well its goin to dealer tommorow. On the way home check engine light came on so I stopped in to the dealer and the Egr cooler is clogged...
They also said sync likely needs a software update. $150. We'll see how it goes...
Old May 19, 2016 | 03:00 PM
rblank's Avatar
rblank
$150 for a Sync update that likely won't work. Good Luck.
https://www.ford-trucks.com/forums/1...l#post16295974
Old May 19, 2016 | 04:19 PM
1turbo6's Avatar
1turbo6
At least it'll be on them.
Old May 20, 2016 | 04:47 AM
JeepPuller's Avatar
JeepPuller
Good luck and post back your results.
Old May 20, 2016 | 11:12 AM
Firekite's Avatar
Firekite
Yeah I want to see how this works out...
Old May 20, 2016 | 03:24 PM
1turbo6's Avatar
1turbo6
Told me that the APIM modulet is toast 750.00 . Wtf... this is B.S. ford knows this is an issue and only covers so.e vin numbers....
Old May 20, 2016 | 03:34 PM
CyberJay's Avatar
CyberJay
There's a ton of APIM modules on ebay for $50-$100. Maybe consult with your dealer and see if they can be programmed for your truck.
My APIM only has one USB port, and I'd like to have two. So I talked to my buddy at the dealership and asked if they were interchangeable. He didn't know, said we could try it if I bought one. I'm trying to decide if I want to risk $50-$100 to find out of it will work.
-J
Old May 20, 2016 | 03:58 PM
Ron94150's Avatar
Ron94150
If you just bought this thing, make the dealer fix it. My dealer would no questions asked, maybe because they want my return business, and I've bought a bunch of vehicles, or maybe it's the 3 day buy back law. They also don't want the reputation of selling vehicles with issues.
Old May 20, 2016 | 04:09 PM
1turbo6's Avatar
1turbo6
Dealer only covers safety related items. But on the way out to dinner tonight girlfriend tried to use the 12v outlet above the sync usb connector and it was dead, maybe it runs on the same fuse?
Old May 20, 2016 | 04:23 PM
  #28
Firekite's Avatar
Firekite
I thought you said you'd already checked all the fuses and such? Maybe check wiring, too?
Old May 20, 2016 | 04:26 PM
  #29
1turbo6's Avatar
1turbo6
I checked the fuse marked sync, and it was fine. Buy maybe the aux 12v outlet has something to do with it? Wishful thinkin.....
Old May 23, 2016 | 04:07 PM
  #30
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
The $150 is for a map update not the sync software update, the software update should be free.
Denny
