What is this?
Old May 18, 2016 | 06:53 PM
Richadortiz's Avatar
Richadortiz
What is this?
Can anyone tell me what this is.
Old May 18, 2016 | 07:12 PM
timmyboy76's Avatar
timmyboy76
Some type of regulated return system
Pikachu's Avatar
Pikachu
Looks like a fuel heater to me.
Old May 18, 2016 | 07:20 PM
Richadortiz
I thought fuel heater too. But why in the world would it need two.
Old May 18, 2016 | 07:24 PM
Pikachu's Avatar
Pikachu
The element in the filter housing is prone to failure, and it isn't nearly adequate. Is yours still connected?
Old May 18, 2016 | 07:25 PM
Richadortiz
Yes it's still working
Old May 18, 2016 | 07:29 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Sounded familiar, found a post regarding it from Y2KW57. LINKY LINKY
Old May 18, 2016 | 10:55 PM
ebbnflow's Avatar
ebbnflow
Looks like a fuel heater for a veggie/WVO system. Do you know the history of this rig?
Old May 18, 2016 | 11:43 PM
aawlberninf350
It's a Van Gogh
From someplace reallllly cold.
Old May 18, 2016 | 11:50 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
It is a supplemental fuel heater. But instead of heating the fuel that goes into the engine, it heats the fuel being returned back to the tank.
This exchanger was designed by Racor, and was adapted by Ford and actually sold by Ford (has an official Ford part number) for the 7.3L. Ford even issued a TSB detailing the installation of this component, which Ford supplied with a mounting plate for the top of the alternator, the two hard fuel return rerouting lines, and the heater hose rerouting line, along with the requisite fittings needed to complete the install. Racor also sold the exchanger separately.
In the stock fuel system, the excess fuel rejected and returned by the regulator (technically, a regulated return, but it isn't called that in aftermarket parlance) does not get a chance to "heat up" in the heads before it is returned. Hence there is no mechanism to heat the fuel in the tank prior to it gelling and getting stalled before it can even be pumped.
Therefore, the two different fuel heaters are not redundant. The bowl heater heats the fuel about to be consumed, and the auxiliary heater uses engine coolant to maintain the fuel supply temperature prior to the fuel pump.
VitaminC
17
Nov 10, 2025 10:54 AM
ZFLASH
Jan 17, 2018 11:26 PM
Allan Hatcher
Ford Truck Parts for Sale
Jul 11, 2015 10:15 PM
Steve Christensen
1947 and Older Ford Trucks
Jan 13, 2011 02:57 PM
green53
Oct 30, 2010 11:27 AM
