Fuel injector pump temperature?
Old May 17, 2016 | 09:50 PM
FutureFordTech's Avatar
FutureFordTech
I was reading about black smoke on my 1900 f250 7.3 and I heard that makes it to hot so I was just wondering how you turn the temperature down or is there something else I need to do
Old May 17, 2016 | 10:10 PM
southern-old-bold's Avatar
southern-old-bold
First and most likely, you have to much fuel. This can be turned down on the injector pump with an Allen hex key, there is a set screw under a small cover in an awkward place on the side of the pump.
Check your air filter first, may need cleaned or replaced, then you are on the right track.
Also second your timing may be out of adjustment. There are stickies at the top of the page to read covering most of this information. Between the stickies, following advice found in them and asking again for specifics you will get to the bottom of this. Presume no turbo
Old May 17, 2016 | 10:41 PM
FutureFordTech
It is a turbo. Will it be the same? It is an ats turbo. And if I was interested in straight piping it, I would cut it off before the cat right?
Old May 17, 2016 | 10:47 PM
southern-old-bold
Check in your area if you can remove your cat but yes straight pipe will help reduce your exhaust gas temperature.
3 inch is probably a happy size.
You still need to go through all that I suggested before.
Old May 17, 2016 | 10:50 PM
FutureFordTech
But just to be sure once I do all the stuff you suggested and I proceed on straight piping it. Do I cut off before of after the cat? Everything I've read says before but someone just told me after so I just would like to be 100% before I cut it off
Old May 18, 2016 | 12:23 AM
PlumCrazy7's Avatar
PlumCrazy7
Put 3 inch as far as you can, as in turbo back.
Old May 18, 2016 | 12:28 AM
Leroy Unlisted's Avatar
Leroy Unlisted
I think a cat in u'r exhaust would be an unnecessary restriction
Old May 18, 2016 | 05:50 AM
bashby's Avatar
bashby
Your truck shouldn't have a catalytic converter.
Old May 18, 2016 | 06:55 AM
IDIoit's Avatar
IDIoit
before you do anything, get a pyrometer.
kinda funny noone has mentioned this.
you need to keep your EGT's (exhaust gas temp) lower than 1200-ish
how much boost is your turbo making? what turbo is on it?
there are a few things you can do to lower your temps.
instead of turning my fuel down, i installed a front mounted inner cooler.
the cooler the air going in, the cooler your EGT's will be.
i have a 3" down pipe, and 4.5"straight exhaust.
no cat. no muffler. i dont even run them on my 2001, which requires
emission testing.
F-250 WARHORSE
Oct 7, 2016 09:41 AM
Realslowww
13
May 29, 2015 11:51 PM
hugger94
Apr 6, 2010 11:08 PM
redneckaggie2008
16
Sep 14, 2007 09:39 PM
lincolntech8105
Apr 20, 2007 09:35 PM
