Wondering if anyone knows if you can bolt up the newer 99 up superduty rear spring hangers (the rear of rear) the bolt holes look to be in the same position in pictures that I can see but has anyone done this before?
The reason I ask is I'm putting in rear superduty leafs and the hangers they use are almost twice as thick as the ones on the truck, I know I can just trim the shackles a bit and they fit but I'd like to use the heavier brackets.
If anyone has measurements (of the superduty brackets) would be greatly appreciated.
The mounting pattern where the bolts/rivets go are completely different. You could weld the newer design on but it won't be as easy as taking your old ones off and bolt the new ones on.
