1979 f150 windshield washer motor
Old 05-17-2016, 07:52 PM
Ronnief150man's Avatar
Ronnief150man
Ronnief150man is offline
Does anyone know if the windshield washer motor is connected to the same fuse as the wiper ****? Wipers work but washer does not. Doesn't even make a sound when **** is pushed in.
Old 05-17-2016, 07:58 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Received 3,408 Likes on 2,529 Posts
No they are not, to ck the switch function are you getting power to the pump/wiring (disconnect the pump plug in the end of the fluid tank) when you push in the w/s switch ?
#4 is the w/s wiper switch fuse.
#11 is the back up lamps and w/s washer fuse.
Old 05-17-2016, 08:26 PM
Ronnief150man
Thank you. I will check when I get the carburetor back on a battery hooked up. Thanks again.
Old 05-17-2016, 09:17 PM
77&79F250's Avatar
77&79F250
After you ck the fuses...No need for a carb or to start or run the truck, just hook up a battery, turn the ing key to the 1st R/H position and hook up a multi-meter to the pump elec connector. Then push the w/s wiper switch in and see if you are getting power thru the wiring to the pump connector.
Could be a w/s wiper switch, washer pump motor or the wiring.
Old 05-17-2016, 10:09 PM
Ronnief150man
Oh okay. I was just gonna get it running first. Carb supposed to be in tomorrow. Thanks
Swenson76
02-26-2018 08:23 AM
Whisk3y
2004 - 2008 F150
06-08-2016 03:32 PM
WW2N
05-26-2016 08:11 PM
1979camperspecial
11-30-2013 01:31 PM
Derrick lane
11-22-2010 05:25 PM
Quick Reply: 1979 f150 windshield washer motor
