window wiper problem
Old Nov 22, 2010 | 01:43 PM
Derrick lane's Avatar
Derrick lane
Wiper motor won't run but fluid pump works. Looked in the original owners manual that came with the truck it said the switch has a circuit breaker in it but the Chilton book said there should be a 10 amp wiper fuse in the fuse box. there is No 10 amp wiper fuse in the fuse box or a place marked wiper on the box lid. So i'm guessing the wiper switch has a c/b in it. As stated the fluid pump works but the wiper motor dose not. So the switch c/b should be OK
1. Would that c/b also protect the fluid pump?.
2. with key on and wiper switch on i should probe 12v at motor plug ?.
Any suggestions ? Thanks
Old Nov 22, 2010 | 02:00 PM
Derrick lane
Easy fix
Should of tried smacking the motor in the first place. A couple taps with a hammer and the wipers work.
Old Nov 22, 2010 | 02:11 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The wiper motor and washer pump is protected by the Circut Breaker in the switch. 7 amp circut breaker.
The Chiltons manual is wrong.
Old Nov 22, 2010 | 02:41 PM
ospreyguy's Avatar
ospreyguy
Sounds like your motor is going bad though... If it does finally go it is a total pain to change. 60 bucks for a new one but you have to remove the hood, vent and in my case replace a broken windshield and repaint a dented hood...
PIA for sure.
Old Nov 22, 2010 | 03:48 PM
Derrick lane
I'll Keep beating it till it is all the way dead it sounds like a pain to change
Old Nov 22, 2010 | 05:25 PM
81-F-150-Explorer
You have to remove the cowl.
Remove the side windshield trim, (the middle windshield trim will come off with the cowl,) the two wiper arms, and loosen the hood and move it forward on it's adjustments, marking the hinges where the hood adjustment was. This will give you enough clearence to remove the cowl, unless the hood is already at it's forward most adjustment.
Tighten the hood with it adjusted forward, so you can push the hood up to work on the cowl, and remove the cowl retaining screws. Remove the cowl. Now you will have access to the wiper motor inspection cover, the wiper linkage, and the wiper motor itself. If the wiper linkage is worn, this is a great time to replace it.
When you get everything back together, don't forget to adjust the hood back into it's proper place.
apache12
Oct 15, 2020 01:51 PM
Tony_C
Sep 10, 2011 09:17 AM
caseymike143
Mar 23, 2011 06:34 PM
HUNTER10
Mar 4, 2007 04:39 PM
ricktoro
13
Feb 6, 2007 08:41 PM
