Changing from solid rear window to power rear window
I'm looking to get a 2014 F150 but the one I'll be getting only has a solid rear window. Has anyone ever removed the solid window to install a power sliding rear window? Parts, pictures, and how to? I'd like to be able to do this at home.
I have a 2014 with privacy tinted power slider and want to switch to solid rear. Will the body control module accept not having anything plugged into it, any trim parts different?
You will need the power rear window, switch and trim piece. The wiring should be there but double check before ordering.
F150, too bad we're on opposite coasts... arrgh.
If you drive up to Washington I'll give you my old one.
