1992 E4OD pump seal questions
Old May 15, 2016 | 04:46 PM
bigredball90's Avatar
bigredball90
My pump seal went on my 92 f350 with a 351. I got the transmission pulled and figured I would upgrade the pump while I was there... Come to find out after I unbolted the pump and started prying on it and spinning it a little bit trying to get it out that I need two slide hammers to get it out. As far as I know the pump is still fine would my little bit of prying and wiggling have messed up anything or can I just replace the seal and bolt it back on and go? Not looking to put to much money in this transmission going to do a diesel swap in the future but want to keep driving it. I would really rather put the 150 towards a trans cooler not a new pump anyway.
Old May 15, 2016 | 04:52 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
if the pump didn't come out, then just put the bolts back in.tap in a new seal and put it back in.with the old seal out,inspect the bushing is flush and didn't walk forward.
Old May 15, 2016 | 04:57 PM
bigredball90
Thats what I was hoping to hear thanks
Old May 23, 2016 | 06:19 PM
bigredball90
Next question is how to get the seal out... Its just been falling apart on me is there a way to do it without the tool?
Old May 23, 2016 | 08:09 PM
FORDF250HDXLT
all you need to do is tap a very thin regular head screwdriver behind the lip and tap and it will lift out.
what's been "falling apart on you" ?
Old May 23, 2016 | 08:27 PM
bigredball90
The seal itself. i was using a pick on the inner part of the seal but then it breaks instead of popping out. I was trying to avoid marring the pump to seal surface.
Old May 24, 2016 | 06:26 AM
Briansshop's Avatar
Briansshop
You'll never get it out that way. Have to get under the metal lip and pry it out like said above.
Powerstroke_73
Jan 13, 2017 07:49 PM
1bigjoe
Jul 13, 2011 08:12 AM
kirbykoon
Nov 24, 2009 09:39 AM
Rickgerald
Mar 22, 2003 10:11 AM
