Driver Side trunk door stuck
Old May 14, 2016 | 08:15 AM
McBrider621's Avatar
McBrider621
Hello everyone first post here,
Recently bought a 2001 excursion my driver side trunk door is stuck shut I have pulled off the back to take closer look somehow looks rusted closed. I plan on drilling it out, unless someone knows where the release is for this mechanism the cable is messed up so I cannot figure it out. Also before i cut it out can anyone tell me the part number for that piece as I have looked for an entire week and have had no luck.
Thanks
Old May 14, 2016 | 10:06 AM
RBerry9511's Avatar
RBerry9511
You should check out the trch folder above. Those doors are commonly referred to as barn doors. I (thankfully) have not had any problems with mine but there are others who have. Good luck. I would not drill anything out unless it is a last resort.
Robert
Old May 14, 2016 | 02:41 PM
Aaron_Jones's Avatar
Aaron_Jones
@RBerry9511 is right the reference material is awesome! Here is a thread that talks about the same problem with some good information:
How to - repairing the drivers side barn door rear latch
Old May 23, 2016 | 07:17 PM
McBrider621
Ok i did what the walk through said but the door wont open at all the cable is fine its the mechanism at the bottom of the door thats messed up because I am moving the piece that is supposed to move with my hands but it will not release. I WD-40d the poop out of it but with no luck. So it needs to be drilled out but problem is I cannot find that part number anywhere for that bottom assembly. I hope someone can help me.
Old May 23, 2016 | 10:26 PM
grif95's Avatar
grif95
Is this what you are looking for?
http://parts.autonationfordwhitebearlake.com/auto-parts/2001/ford/excursion/xlt-trim/7-3l-v8-diesel-engine/body-cat/cargo-door-scat
Old May 24, 2016 | 11:31 AM
McBrider621
Yes thats what im looking for but problem is where is the lock asy for the driver side barn door.
I see the passenger but i dont see the drivers with the cable etc.
Old May 24, 2016 | 01:22 PM
BroncoRN's Avatar
BroncoRN
Google Autonation Ford White Bear Lake. Give them a call in the parts dept. I got the whole assembly from them, I think it was $60. Drill out the plastic rivets and replace the entire assembly. You will have to rivet the new assembly in as well.
In the meantime you can remove the door panel and pull the cable by hand to open the door.
Old May 24, 2016 | 07:03 PM
McBrider621
Unfortunately the cable was not the problem i think the locking mechanism is rusted closed the part that makes the lock unlock is stuck shut somehow. I will give them a call in the morning thanks.
GavinL
Nov 21, 2018 12:51 PM
renchr56
Sep 22, 2016 03:38 PM
BocceMon
16
May 23, 2014 04:09 PM
Mocha Joe
May 29, 2013 05:34 AM
krzldy1949
1997 - 2003 F150
Mar 9, 2013 12:39 PM
