P0246e Code
May 13, 2016 | 02:06 PM
P0246e Code
My check engine light was on today. Don't know when it came on, could have been yesterday or today as I heard no chime. My H&S reported it as P0246E which isn't in the list. Is this a variation of the Turbo wastegate code?
I cleared it for now.
May 13, 2016 | 02:54 PM
May 14, 2016 | 06:55 AM
Quote:
Originally Posted by
69cj
Thanks, didn't know if the E suffix meant anything to change what the code was reporting.
May 14, 2016 | 07:59 AM
PlayersZ28
Google is your friend. lol
May 14, 2016 | 08:12 AM
69cj
yup, already did that and no matches with the "e", maybe it's just the H&S adding that, if I see it again I'll use one of my other scanners.
May 14, 2016 | 02:26 PM
PlayersZ28
I found the code with the e at the end but they only referred to VW's and didn't state anything different than the non e code.
May 14, 2016 | 08:37 PM
P0246 or P246E?
Are we talking P0246 or P246E? I suspect P246E is the correct DTC. If so, you likely have a failed or failing EGT 1_4 sensor.
May 14, 2016 | 10:51 PM
Better get that taken care of if it is a failing EGT sensor.
May 15, 2016 | 01:35 PM
m-chan68
Doh! You're right.
Just checked the pic I took of it again and it's P246E, not P0246E. So it's an EGT sensor code.
May 15, 2016 | 02:27 PM
PlayersZ28
Doh! You're right.
Good catch Mike.
May 31, 2016 | 12:50 PM
Found a letter on my desk from Ford that EGT sensors are warranted for 11yrs/192kkm, whichever comes first. Next time I get the code I'll take it into the dealer. Not sure if they can picked up a stored code from the last time it was on.
May 31, 2016 | 01:04 PM
Not if you cleared it. But if it went off, or if it is pending again it will still be there.
jwsrules
6.7L Power Stroke Diesel
Aug 7, 2024 08:09 AM
cmdevildog16
Jan 28, 2012 09:30 PM
55F250
General Automotive Discussion
Sep 5, 2009 02:14 AM
whtrdng
Jul 8, 2009 07:44 AM
That_Guy
Jan 2, 2008 06:45 PM
