superchips tuner for 5.4
Old Aug 15, 2003 | 01:04 AM
north west expy's Avatar
north west expy
has any one here used one? was it worth? what did you actualy get from it? would you recomend it to a friend? any input would be great.. thanks for your help..
Old Aug 15, 2003 | 09:37 AM
buzzard's Avatar
buzzard
Excellent product and mod. I'd highly recommend it as the most bang for the buck. I installed the "preset" code, but one day I might get creative. I've also scanned my PCM for codes, but haven't had any.
Old Aug 15, 2003 | 06:09 PM
north west expy
what kind of gains did you see? have you had any problems resulting from this mod? thanks..
Old Aug 15, 2003 | 09:46 PM
buzzard's Avatar
buzzard
Of course any gains are "seat of the pants" gains without the benefit of an engine dyno, but I've noticed my Expy is much more responsive down low. Mileage increased by 1/2 to 1 mpg too. No problems.
Old Aug 16, 2003 | 01:59 PM
north west expy
thanks buzzard..
Old Aug 17, 2003 | 09:26 AM
BigMattXXL's Avatar
BigMattXXL
Buzzard-
Does the superchips tuner allow you to make adjustments to just the transmission? I don't want to run premium gas.
XXL
Old Aug 17, 2003 | 10:13 PM
buzzard's Avatar
buzzard
Originally posted by BigMattXXL
Buzzard-
XXL
....honestly don't know if you can or can't. I read through my operator's manual and from what I saw, it doesn't say. I think 99.9999% of people who purchse a superchip buy it for the the engine performance enhancements not the auxiliary or tertiary functions. One does have the option to install the standard preprogrammed superchip tune or to customize through a long series of Q&A's. I opted for the standard program. Maybe one day I'll do some experimenting with shift pressures, shift points, gearing, tire size, etc.
You might want to pose the question to superchips directly. I emailed them with questions when the 1715 first came out and they got back with me a day or two later.
Good Luck.
Old Aug 17, 2003 | 10:40 PM
BigMattXXL's Avatar
BigMattXXL
Thanks Jim - will do.
XXL
Old Aug 18, 2003 | 09:15 PM
FTE Ken's Avatar
FTE Ken
No, you cannot make just transmission adjustments. It requires the premium fuel program to be installed if you want to make tranny adjustments.
Old Aug 18, 2003 | 11:28 PM
BigMattXXL's Avatar
BigMattXXL
Red face superchips tuner for 5.4
NOOOOOOOOOOOOO!!!!!!!!!
you animal!!!!!!
LMAO
XXL
Old Aug 19, 2003 | 01:30 PM
Petrol's Avatar
Petrol
I just spoke with a SuperChip distributor and was told that the "New&Improved" MicroMax Tuner allows you to select from Four (4) separate states of 'Tune'
1. oem
2. Reg Unl performance
3. Super Unl performance
4. Towing
I was also told that you can select to 'firm-up' the transmission, recalibrate your speedometer and shift points to compensate for oversize tires / gear changes, adjust the speed limiter, etc.
sounds like SuperChips has been busy!
Old Aug 20, 2003 | 05:38 PM
buzzard's Avatar
buzzard
1. oem ----- Everybody has this option whether they have a chip or not.
2. Reg Unl performance ----- Why bother unless you can't get Super Unleaded gasoline? Performance gains would be very minimal.
3. Super Unl performance ----- Already standard with chip or tuner
4. Towing ----- Have no idea on this one, but how much different can it really be?
I was also told that you can select to 'firm-up' the transmission, recalibrate your speedometer and shift points to compensate for oversize tires / gear changes, adjust the speed limiter, etc. ----- Existing tuner does all this
Old Aug 21, 2003 | 01:17 PM
Petrol's Avatar
Petrol
Originally posted by buzzard
YES BUT, It is much easier to simply hook up and download the oem program (with no trace of PCM access) then it is to dig around in the passanger foot well to pull a chip out before taking you truck in for warrenty service!
TRUE BUT, while hp & torque gains would be minimal at best, you STILL get the improvements in transmission shift qaulity/speed, speedometer/axle ratio calibration, all nice features that can be enjoyed while you 'burn-off' a tank or two of cheaper reg unl gasoline. Perhaps when traveling and outright performance isn't needed or good quality premium unl is not available!
YES BUT, the standard tuner isn't as feature packed as the new one . . . a chip suffers somewhat from lack of 'quick change' flexiblity (on a mildly moded engine)
WELL, from what I am told they (SuperChips) really tweeked the 'performance' setting to the max . . . the 'towing' setting is roughly the same as the 'old' chip/tuner performance settings
YES it sure does . . . but this is NEW, lol
Old Aug 22, 2003 | 10:05 AM
buzzard's Avatar
buzzard
Hey Petrol, I'm not debating you, but I just don't see TOO much added benefit in the new tuner compared to the existing 1715 tuner that I have. I'd bet that one couldn't tell the difference between the three performance choices in the new tuner compared to the existing superchip performance program in a "blind taste test."
Old Aug 24, 2003 | 09:56 AM
Petrol's Avatar
Petrol
I'm sure you are very correct Buz! As Large and heavy as the Expy is I think it takes at least a 20hp increase to be able to feel the differance.
A/Ox4
Aug 5, 2011 06:59 PM
rdweathers
Apr 4, 2011 08:23 AM
Kris Guilbeaux
Sep 24, 2004 11:17 PM
ford390gashog
General Automotive Discussion
25
May 24, 2004 01:24 PM
kens72highboy
Nov 18, 2002 11:55 PM
