Distributor advance
Old Apr 3, 2011 | 07:44 PM
rdweathers's Avatar
rdweathers
Distributor advance
Any perferances for distributor advance vacum or mechanical? Why would you pick one over the other?
Old Apr 3, 2011 | 08:06 PM
fmc400's Avatar
fmc400
MSEE
You need both. Mechanical advance advances the timing based on RPM; vacuum advance advances the timing based on load. The factory distributor employs both.
Old Apr 3, 2011 | 08:31 PM
rdweathers's Avatar
rdweathers
What if you are going to a new aftermarket distributor, why would you pick a non vacum advance over vacum?
Old Apr 3, 2011 | 11:34 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
Its for race/higher hp motors typically those that run nitrous or or lots of boost.
I am not sure how they work with it totally, but I have seen my friend set his 250 shot of nitrous up that way based on a book, and expert advice.
On a street motor you will give up power as you accelerate, and probily loose a good chunk of mpg's.
Old Apr 4, 2011 | 08:23 AM
fmc400's Avatar
fmc400
MSEE
^^^ What he said. If this is a street-driven engine, vacuum advance is absolutely necessary.
V10man
Feb 2, 2013 11:35 AM
Ooftus
Jul 15, 2010 02:37 AM
idaho211
Jan 24, 2009 03:07 PM
TMI
Dec 27, 2002 04:03 PM
adelyser
1978 - 1996 Big Bronco
Jan 18, 2002 10:47 AM
