RAG JOINT ?
Old 05-12-2016, 10:58 PM
72CC428's Avatar
72CC428
72CC428 is offline
RAG JOINT ?
I have this copper "band" That goes from one of the pins to one of the bolts. What is that for?
Old 05-12-2016, 11:44 PM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is offline
Picture for clarification?
Old 05-13-2016, 02:46 AM
72CC428's Avatar
72CC428
72CC428 is offline
Pics
I'll get some pics when the sun comes up.
It's on the column side of the joint it looks like it would have to do with electrical but I don't see a purpose.
Old 05-13-2016, 07:29 AM
72CC428's Avatar
72CC428
72CC428 is offline
Got Da Pic's
Here are a couple of pic's, bear with me my Camera is FUBAR.
Old 05-13-2016, 07:38 AM
hillcountryflt's Avatar
hillcountryflt
hillcountryflt is offline
I believe the copper piece on your rag joint is for helping the horn work - grounding the steering column to the frame. When working on them, they may break, so some use a short run of wire to make the connection.
Old 05-13-2016, 07:49 AM
vidaliaman's Avatar
vidaliaman
vidaliaman is offline
Yes, the copper band allows for your horn to be grounded properly, i'm installing a new rag joint myself
Old 05-13-2016, 09:29 AM
72CC428's Avatar
72CC428
72CC428 is offline
That's what I was afraid of. I broke mine. Any way I can solder this together? It broke at its thinnest point (of course).
Old 05-13-2016, 09:40 AM
hillcountryflt
Don't worry about it. Just create you a short jumper wire to connect either side of the rag joint.
And to be honest, I broke it on one of my trucks and the horn still worked without the jumper. Later I replaced both rag joint units.
Most of the parts houses will carry this unit - either the replacement rubber part (about $10) or the whole assembly for less than $40.
Lares Steering Coupler 202: Advance Auto Parts
Old 05-13-2016, 09:52 AM
orich's Avatar
orich
orich is offline
The Grounding strap flexes a very small amount you can make one from stranded copper wire.
Orich
Old 05-13-2016, 11:28 AM
72CC428's Avatar
72CC428
72CC428 is offline
NO SOLDER HUH?
So I can't solder this?
Thanks HCF, Orich, and others who helped.
If I can't solder it I'll follow y'alls advice.
Old 05-13-2016, 12:37 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1967/68 F100/350 uses a different steering coupler than 1969/72 F100/350.
Old 05-13-2016, 12:44 PM
orich's Avatar
orich
orich is offline
Yeah sure you could solder it by bridging small strands the width across the break, but how long will it last until it has to be replace.
I'd look for some kind of braided copper/cable to eye loop terminal on each bolt end.
May be type of cable that is used for hood to body grounding or engine to body grounding if braided.
my.02
Orich
Old 05-13-2016, 07:31 PM
elkycali's Avatar
elkycali
elkycali is offline
Hey there! These are plentiful in the salvage yards and would probably cost you about $5 which is what it cost me. A lot simpler and cleaner than jerry rigging one up with wire in my opinion...Al
Old 05-13-2016, 07:40 PM
elkycali's Avatar
elkycali
elkycali is offline
A quick check at my local Autozone and they have them for $5.99
Old 05-13-2016, 10:47 PM
72CC428's Avatar
72CC428
72CC428 is offline
Good Idea
my.02
Orich
I believe I am going to do just that. Thanks Orich. g
I'm going to take the two ends and fold each over the ends of the braided wire, and solder.
Whaddaya' think?
Quick Reply: RAG JOINT ?
