2015-16 coil spring codes
Old May 9, 2016 | 04:57 PM
radium's Avatar
radium
I'm sure this has been asked a million times and I looked but I couldn't find an answer. The sticker on my door says 6000 pound GAWR front what Springs would I have on the truck then the 5600 pound or the 6000 ??? Getting ready to mount my plow just want to make sure I can do it with the added weight of the diesel engine in the front I'm worried about the extreme V 2 9.6 . It wasn't a problem for my 5.4 but I had beef that up it weighs close to 1044 pounds it's a lot of weight up front thanks again
Old May 10, 2016 | 01:46 PM
radium's Avatar
radium
wow no one??? well here is the number on spring 5AC R060A cant find it on line ??? what is that 5600 0r 6000 ???
Old May 10, 2016 | 02:49 PM
smoky_diesel's Avatar
smoky_diesel
https://www.fleet.ford.com/truckbbas...SB_Updates.pdf
Go to fordparts.com for PN to spring rate x-ref. Note PNs can be year specific.
MY16;
F81A-5310-AHD = 6000
F81A-5310-AGD = 5600
I took out 5C34-5310-ACC out of my '14 which are 5600, as I have a CCLB w/ camper package.
Old May 10, 2016 | 04:16 PM
radium's Avatar
radium
???? i don't get it i cant find that number ???? where is that part number listed ?
Old May 10, 2016 | 04:20 PM
radium's Avatar
radium
ok found it 5C34-5310- ACD thanks
can not find ???
Old May 10, 2016 | 04:44 PM
radium's Avatar
radium
Okay I ripped the tag off the spring here's the number I can't find it anywhere they all seem to end with a B m
ine ends with D??
Old May 10, 2016 | 05:28 PM
Just Strokin's Avatar
Just Strokin
See if this helps
Old May 10, 2016 | 09:19 PM
radium's Avatar
radium
wtf is that lol where is my number lol . or just what is the spring ??? 5600 or 6000 lbs???
Old May 11, 2016 | 06:11 AM
ruschejj's Avatar
ruschejj
Have you ever weighed your truck, getting the front and rear numbers?
I don't recall ever getting close to 6k up front personally, I doubt you have anything to worry about, other than just satisfying curiosity.
Old May 11, 2016 | 11:08 AM
smoky_diesel
That is someone trying to help you.... aka your question answered
'-ADC' = code x = 4000lbs
-5310-AHD = 6000
-5310-AGD = 5600
-5310-AFD = 5200
-5310-AED = 4800
-5310-ADD = 4400
-5310-ACD = 4000 <- you are here
Old May 11, 2016 | 03:10 PM
radium's Avatar
radium
thanks anyways but you are all wrong went to dealer today in Albany 6000 pound springs number changed for 2016 it was a nightmare to find cross reference that number on my truck and this is what he came up with lol ford why so hard ??? take care
Old May 11, 2016 | 03:15 PM
radium's Avatar
radium
[QUOTE=smoky_diesel;16276837]That is someone trying to help you.... aka your question answered
-5310-AHD = 6000
-5310-AGD = 5600
-5310-AFD = 5200
-5310-AED = 4800
-5310-ADD = 4400
-5310-ACD = 4000
the last letter is the code thanks you for trying two stickers on springs lol why ????? dealer thinks that is what is normal and then snow plow up ???
Old May 11, 2016 | 03:27 PM
radium's Avatar
radium
why?? because i don't want airbags in my plow truck driving 60 miles round trip when i am plowing all day
Old May 12, 2016 | 08:32 AM
radium's Avatar
radium
Just a quick update went to my actual dealer today where I purchase the truck they had no parts guy yesterday. Basically the number on the spring is a engineering number you have to enter it into the system each year for a truck to get the proper number and they're different part number for each side and of course changes year-to-year I just don't get it but the good news is I have to six thousand pounds Springs, he said it's very rare that a 11500 pound truck would have less Springs doesn't mean it can't happen but especially with the upgraded plow package once again thanks for everyone's help this is extraordinary research even the dealer had to go through to get the right number take care
Old May 12, 2016 | 08:02 PM
ruschejj's Avatar
ruschejj
Why? If your springs are rated for 6000 and your front end is 5500, if you add a plow you're over.
If your springs are rated for 4000 and the front end is 3000, adding a plow will send you over.
If you don't know what weight is sitting on your front and rear axles then you don't know if you are over or not?
It's strange to be wrapped up in how much weight your springs are rated for yet you have no idea how much weight is on them?
If you know one answer but not the other, you've got no answer.....
