Engine stumble...
Just a quick one before I turn to your plans. Does anybody happen to know what the main difference is between these two seats ?
Autolite 4100 Carburetor Needle & Seat
Motorcraft 2100 2150 Needle & Seat
I pulled the bottom one out, but my rebuild kit came with the top one.
Thanks a lot !
Martin
Found the cause of the flooding today, after re-digging through the rebuild instructions. Forgot to put the gasket underneath the seat..... that's why it was flooding..... Put in the seat that came with the overhaul kit, installed the gasket, set the fuel height and idle and went for a spin..... prrrrrrrr.....prrrrrrr....prrrrrr.... purring like a little kittycat......
Only thing remaining is the stumble. Now, I'm convinced it's not carb related and I'm about to live with it. Will try some more of your suggestions, but I'll start enjoying driving my Bump ( he's called Jeff by the way ) again !
Thanks, any other ideas are always welcome !
Martin
My '79 did that, and I cant remember what ended up being the fix. I know that it had a 2 stage pv in it when I bought it, also the spring was weak and wasnt pulling the throttle right, and the jets were too small. 2100 should have #55F.
Edited to add: Ok, I looked at my thread from 2013. Turns out there was a bug wing in one of the jet holes. Maybe pull the top and see whats in there.
So he should verify that his carb size and jets are correct.
Also, when checking for vacuum leaks, if you are using brake cleaner you need to read if it is non-chlorinated or chlorinated. Chlorinated is non flammable.
Next thing will be to stop the brake caliper rattle at the front. Have read some useful intel already on the forum, so I'm anxious to get started !
Take care,
Martin
What remains is the stumble of idle....went to my tuner again and to fix the lean condition, he has blocked the ram air on the idle circuit, in order to richen the idle. This didn't help, so we tried to advance the vacuum advance to the lightest setting, but his was already in that position. Than we tried to connect the vacuum advance from carb vacuum to manifold vacuum and that showed a slight improvement. Am I correct in thinking my basic ignition timing might be too late ? So, if I advance the distributor a little, it might solve this issue ?
If that doesn't help, I'll quit looking for solutions this summer and enjoy my truck to the fullest, whilst dealing with the off idle stumble....
Do these correctly with a timing light and dwell meter. A person shouldn't skimp on things when trying to solve a problem. This can cause all kinds of parts being thrown at something when a tech was right in the very beginning.
Another thing to look at, the butterflies should be almost completely closed at idle, the only thing that should be exposed is the T-slot, meaning only the idle circuit is providing fuel at idle. Everything has to be adjusted in the ballpark all the way back from tank/fuel pump to properly set idle mixture, or an off-idle stumble can be just one symptom.
You also mentioned earlier not getting a good accelerator pump shot squirt until 3/4 when actuating the throttle. Did that get fixed? It HAS to be immediate to prevent a "bog" or stumble. Actuating rod inboard slot, and second hole from the top in 40F to 80F temperatures.
Back again after enjoying my Bump during a very nice Dutch summer !
The stumble is still there and I was getting used to it, but the issue is haunting me again... but, instead of trying and trying and trying, I want to buy a new carb for the Ford. Can anyone tell me what would be a nice replacement carb for a totally stock 360 ? Edelbrock ? Or another brand ? I'm also wondering about replacing the exhaust manifolds for headers and exchanging the exhausts....
Thanks, it's good winter kicks in, so I can start working on the Bump again...
Bye,
Martin
Bye,
Martin
AFAIK where you are gas is expensive. 360/390s are not fuel economy engines at all. So if you end up with stock exhaust I would suggest the following.
- 390 CFM Classic Holley Carburetor
Larger Image
Electric Choke Vacuum Secondaries
PART# 0-8007
Suggested Retail: $529.95
Holleydays Price: $429.26
Free Shipping on orders over $100*
Qty:
Add To Cart
Overview
Classic Holley carbs have been a staple for rodders around the world for decades. They're calibrated for use on stock to mildly modified vehicles and have that classic Holley look. Holley’s 0-8007 is calibrated and intended for small V8s or 6 cylinder engines as well as 2x4 street tunnel ram style set ups. Plus, it is Gold Dichromate coated for durability and classic Holley looks. Don't trust your performance to just anyone, Holley is the only modular carburetor company that has been in business for over 100 years and has powered every NASCAR champion since the 60's.
Features:
- Gold Dichromate finish for corrosion resistance and classic Holley looks
- Calibrated and Intended for small V-8 or 6 cyl. engines & 2 x 4 streettunnel ram set-ups
- Factory preset electric choke for easy startups
- Vacuum secondaries for use on wide variety of vehicles. Compensate for all vehicle weights, gearing & transmissions to allow smooth opening of secondaries.
- Single feed fuel inlet for easy installation
- Power valve blow-out protection
WARNING FOR 0-8007: This product contains chemicals known to the State of California to cause cancer and birth defects or other reproductive harm.
*Free Shipping & Han
Also Bought
10" Chrome Round Air Cleaner
Chrome Round 10" Air Cleaner Assembly, Fits Carburetors...
Part# 120-145
$32.24
14" Chrome Round Air Cleaner
Air Cleaner Assembly, 14" Round Design w/paper element, Triple...
Part# 120-102
$39.62
Ford Trans. Hardware Kit
Trans Kickdown Hardware kit w/2 Mounting Holes
Part# 20-91
$8.78
Some parts are not legal for use in California or other states with similar regulations.
AND
Edelbrock Performer Intake Manifolds 2105
- 600 CFM Classic Holley Carburetor
Larger Image
PART# 0-80457SA
Suggested Retail: $356.95
Holleydays Price: $288.86
Qty:
Overview
Holley’s new 0-80457SA is constructed from aluminum which compared to its zinc counterpart equates to a weight savings of 40%! Holley’s aluminum 0-80457SA will hold its shine longer and also can be hand polished for a custom look! Its 600 CFM of airflow, vacuum secondaries, and single fuel inlet makes it amazingly universal. Add to that an electric choke and this carb is super easy to use on almost anything. Don't trust your performance to just anyone, Holley is the only modular carburetor company that has been in business for over 100 years and has powered every NASCAR champion since the 60's.
Features:
- Vibratory polished aluminum for good looks, weight savings and long lasting shine
- Performance upgrade for stock to mildly modified vehicles
- Universal calibration for easy bolt-on performance
- Compatible with GM, Chrysler, and Ford A/T kickdown linkage. Additional parts may be required.
- 100% wet-flow tested by Holley technicians to assure it arrives ready to run!
