Modular V10 (6.8l)
Please Help ID This Hose
Old May 8, 2016 | 07:30 PM
jrod1101's Avatar
jrod1101
Hi there! My name is Jimmy and this is my first post. I usually can find the answers to my questions by just using the search function but I could not on this one. I have a 2001 E-450 V10 RV that is throwing codes P0174 and P0171 per AutoZone. These pictures are not of my exact engine and two that I located during my search. On my engine this hose is rotted out and I can pinch it with my two fingers it appears heat rotted. As soon as I touch the hose it falls apart.
Please help me ID the hose that has the red arrow pointed to it in the photo below:
Thank you for taking the time and looking at them to try and help me ID them.
Jimmy
Old May 8, 2016 | 08:00 PM
Bently_Coop's Avatar
Bently_Coop
Can you not trace it underneath and just replace? It looks like a Vacuum hose which can be purchased in bulk from most auto parts stores.
Old May 8, 2016 | 08:08 PM
jrod1101's Avatar
jrod1101
I will be going out to the RV Storage this weekend to try and trace it away from the engine. I will replace and advise if it fixes the problem. I was hoping someone could tell me what it attaches to.
Thanks,
Jimmy
Old May 8, 2016 | 08:45 PM
Sam I Am's Avatar
Sam I Am
To replace it you will need to remove it first. Then you will see what it attaches to.
Old May 8, 2016 | 09:51 PM
Harryjt's Avatar
Harryjt
that hose is the vapor line from your tank the one side goes up to the engine that is controlled by the computer to draw the vapor into the intake the other side at the Y goes to the charcoal canister on the driver side wheel well. replace the hose with fuel rated rubber and you will be all set
Old May 9, 2016 | 05:57 AM
JWA's Avatar
JWA
Yep, 100%!
As mentioned in the other thread posted in the Vans Forums Lean Bank 1 & 2 codes are typically found to be the PCV hose leading to the back bottom of the throttle body. Someone here should know the proper part number for its replacement.
Old May 9, 2016 | 09:57 PM
jrod1101's Avatar
jrod1101
Thank you all for the information! I appreciate everyone's comments to help me fix this issue with my RV. I will reply with more once I get it fixed.
Respectfully,
Jimmy
sunuvabug
Aug 24, 2017 07:31 AM
jrod1101
May 9, 2016 09:58 PM
97REDPSD
Jul 22, 2011 10:53 PM
lance65
Mar 4, 2008 07:34 PM
tb1998z71
1983 - 2012 Ranger & B-Series
Apr 12, 2006 11:38 PM
