Modular V10 (6.8l)
Serpentine belt pulley bearing?
Old 05-06-2016, 04:28 PM
dcgayhart's Avatar
dcgayhart
dcgayhart is offline
Looking to replace the bearings in my idler pulleys and tensioner during engine swap. Anyone know the bearing size offhand? If not I'll punch them out and measure. I know you can buy the entire assembly ($10-$30 ea.) but the bearing alone are very reasonable and I have a press.
Old 05-07-2016, 02:18 AM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
Don't have the bearing measurements however the Gates Idler pulleys aren't too expensive.
Old 05-07-2016, 05:40 AM
JWA's Avatar
JWA
JWA is offline
Received 1,411 Likes on 1,112 Posts
You'll have as much time trying to replace bearing in that device as you would replacing it outright---for a $20 savings?
Old 05-09-2016, 09:42 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Just get the number off the bearing and look it up.
The idea of replacing just the bearings is a good one, especially when you can find GOOD bearings from a manufacturer that you wouldn't normally find in an as-supplied pulley
I've used Gates and Dayco pulleys a few times on my modulars - the bearings usually start to whine within a year or two.
Next time, I'm just going to replace the bearings themselves with known-good parts.
villestrip
01-21-2017 01:59 PM
madpogue
13
01-09-2016 10:24 AM
abyars111
02-26-2014 09:51 AM
3wildboys
12-21-2011 08:05 PM
Russell Avery
Garage & Workshop
08-18-2002 11:33 AM
Quick Reply: Serpentine belt pulley bearing?
