Sponsored by: Real Truck
Door Chime
Old May 5, 2016 | 10:42 PM
bennya1's Avatar
bennya1
Door Chime
Does anybody know how to disconnect the door chime? I like to keep my drivers door open while I listen to the radio and it would be nice to not have the annoying chime ring.
Old May 5, 2016 | 10:56 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I cut a wire coming from the ignition in the steering column. Black w/ pink trace? I'm trying to confirm, but side effect is the door automatically unlocks itself everytime I close the driver's door, and I have to lock it with the fob.
Post #35 comfirms I cut a black w/ pink trace wire in my '07. It worked up until that year, we'd need an 08" wiring diagram to be 100% sure:
https://www.ford-trucks.com/forums/4...ml#post3854011
Old May 5, 2016 | 11:39 PM
RainDesert's Avatar
RainDesert
I went this route and will again on my next SD. :
https://www.ford-trucks.com/forums/1...er-delete.html
Old May 6, 2016 | 10:04 AM
texastech_diesel
Token Redneck
Yeah but doesn't that kill the headlight warning as well? Plus ANY alert noise, ie low fuel, "check gauges", all that.
Old May 6, 2016 | 10:21 AM
RainDesert's Avatar
RainDesert
Yes you lose the headlight reminder so one must remember without the chime reminder. I have never heard of the chime for warning lights. I know on my friends new 6.7 no audible alarm went off when all his dash warnings lights were flashing leaving his truck disabled on the side of Hwy20.
Old May 7, 2016 | 08:02 AM
wrvond's Avatar
wrvond
That would indicate another problem with his truck. Every visual alarm is accompanied by an audio alarm. Everything from "low fuel" to "parking brake engaged".
Old Jun 5, 2016 | 10:15 PM
mcwhirtj's Avatar
mcwhirtj
I posted pictures on how I disabled the "key in ignition, door open" chime in a new thread. I found various threads but none with good pictures showing how it is done. This was for my 2005 F250.
Jim
https://www.ford-trucks.com/forums/1...-pictures.html
Old Jun 7, 2016 | 10:46 PM
nogo73's Avatar
nogo73
I de-soldered the chime out of my gem module. works great! (it the only large black cylinder) no chime for seat belts or anything.
Old Jun 8, 2016 | 02:56 PM
Sir Kayakalot's Avatar
Sir Kayakalot
Nogo73 can you explain what you did a little more in detail please
Old Jun 8, 2016 | 04:25 PM
nogo73's Avatar
nogo73
So what I did was pull out the gem module / fuse box on my 2001 f350. I opened up the gem module and de -soldered the diode chime leaving an open I reinstalled the gem module and fuse box. and I never heard a chime again . this is what it looked like it was by the corner of the board of the gem module. I also siliconed the gem module case to prevent an more moisture.
Old Jun 8, 2016 | 04:56 PM
nogo73's Avatar
nogo73
here is an image of the gem module you can open it up to reveal the circuit board.
Old Jun 9, 2016 | 09:05 AM
wrvond's Avatar
wrvond
Here you go:
Shadow351
1997 - 2003 F150
Jan 15, 2011 11:30 AM
cfd29
Sep 4, 2007 09:43 AM
tomtexas
Mar 7, 2004 08:12 AM
streadway
1997 - 2003 F150
Sep 15, 2003 09:53 PM
