Thank You
Old May 4, 2016 | 06:00 PM
MattyP10178's Avatar
MattyP10178
Trailering
Thank You
Just wanted to say thanks to all that helped me get my truck running right. Replaced the coolant with Rotella ELC, after a flush with Restore and Restore+. Then I changed out the Oil cooler and EGR cooler because the oil cooler was plugged(20°+deltas). Replaced all filters with Motorcraft, rebuilt the turbo, and a glow plug install. Honestly, I would not have been able to do it without all the posts that you fellas posted. Had an issue with alligning the Y-pipe with the turbo, and I remember reading that you can use a ratchet strap and pull it together using the hole above the passenger headlight. Worked like a champ. Crusing down the road at 70 mph, for about 45 mins. seeing deltas around 9.9. What a difference! I cant wait to cut open the old oil cooler and see how plugged it was. The only stuff that I have to do to make everything the way I want is to replace all 4 shocks,diagnose a wheel bearing issue, and alignment. Thanks again
Old May 4, 2016 | 06:31 PM
04superduty6.0's Avatar
04superduty6.0
This is why I love this site.
Old May 4, 2016 | 07:52 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
^^^^ 2
There is NO other forum like this one.
I have been bit by the Rubicon bug and will likely have better luck here than in a jeep forum... Get ready fellas!
Sure glad you got your issue resolved!
Old May 4, 2016 | 08:14 PM
TxMav's Avatar
TxMav
Yes. Awesome group here. They have helped me a bunch.
Old May 4, 2016 | 08:55 PM
Misky6.0's Avatar
Misky6.0
Originally Posted by Shaneb75
^^^^ 2
Cool, we have a 2000 TJ and hangout on the wranglerforum occasionally at the moment. Once we finish a house in CO I'll be able to start "working" on out Jeep which we keep out there.
Old May 5, 2016 | 09:54 AM
04superduty6.0
Look out guys, we have a 2004 TJ and occasionally go to the Wrangler forum also. Maybe we should start a sub forum for the Jeep owners. lol
diggintrenches
Mar 4, 2014 10:20 AM
coolchange
May 19, 2013 12:55 PM
Mrcastrovinci
Nov 24, 2011 08:52 PM
White F250
Mar 14, 2011 09:06 PM
dredmond
Mar 11, 2011 07:59 PM
