Irregular EOT and ECT readings
Old May 17, 2016 | 02:35 PM
WatsonR's Avatar
WatsonR
Originally Posted by 69cj
Personally anything under 190 should get a new t-stat. The warmer a diesel runs, too a point, the more efficient it is since it relies on heat and compression for combustion.
I agree. Anything thing under 185 will cause the truck to open-loop the fuel trying to warm up. Hotter is better, 210 is perfect.
He replaced the sensor and said it fixed it... no, I don't think it did. At this point, it's not about the differences it about a faulty thermostat. Once that is replaced and your temps are back to 190+ ECT, then look at the difference.... until then, your wasting your efforts on looking at EOT/ECT.
Missing is another issue. Have you read the codes?
Old May 17, 2016 | 07:02 PM
fordtruckrodder's Avatar
fordtruckrodder
Sorry I should have stated since changing the coolant sensor my FWT and EOT temps have been in the 175 to 188 degree range, unloaded at interstate speeds. Before having this problem the only time I've seen 210 is towing at interstate speed. Should the temps be higher than this? It does seem like my water temps rise faster than the oil temp.
My cel never came on, I checked for codes using the SGII but there wasn't any.
Old May 17, 2016 | 07:09 PM
WatsonR's Avatar
WatsonR
The ECT should be at least 188, but 192° is the factory setting of the tstat. If your not consistently getting to 190° or very close.. or more, change it.
Old May 18, 2016 | 08:03 AM
69cj's Avatar
69cj
The factory t-stat in my 05 always ran between 198 and 204. Same t-stat in it for 10 years.
Old May 20, 2016 | 03:11 PM
fordtruckrodder
I will change the thermostat, is there any particular brand I should get?
Old May 20, 2016 | 04:38 PM
69cj's Avatar
69cj
OEM in my opinion.
Old Jun 27, 2016 | 05:37 AM
fordtruckrodder
I changed the thermostat with a motorcraft unit. All seems to be ok as far as temps go. My eot and fwt are staying about 190 range now. As for the miss it's still present. I will post another question just for that.
Thanks for the help.
Old Jun 27, 2016 | 09:02 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Diesels like to run closer to 200*. I installed the Mish-moto and Brute loves it!
TJK1
Jun 17, 2013 06:46 PM
Stealth94rttt
Feb 21, 2013 04:08 PM
jmullikin7
Feb 2, 2013 09:11 PM
hndacr
Jun 2, 2010 08:31 AM
dave_f250
2004 - 2008 F150
Dec 16, 2009 08:35 PM
