I'm working on this 2004 F-150 Supercab STX 4x4 4.6 V8. For a customer. The customer complaint is that on cool or cold mornings, the truck will do a near-stall and shudder somewhat with little or no response for sometimes 10 seconds upon acceleration from that first stop after a cold start. The rest of the stops, no problem. The rest of the day, no problem. I have done some things to the truck to address this problem, but to no avail. Check engine light was on for a short time, code was for Cyl .Head Temp Sensor. Replaced that, and the temp guage reads pretty low now. Any ideas are appreciated, I need to hear them all.
Everytime I hear stall or shudder on those I pull the coils and plug boots before anything else. Look for signs of arcing on the boots or any condensation on them or in the holes. Just a little tiny bit can cause it.
That temp sensor code could have been caused by the thermostat not working. I've seen it before.
I've seen moisture do that a lot. Also small cracks in the boots can be open on a cold engine letting a missfire happen. The heat could be causing them to swell. Moisture down there is the cause of probably 90% of the problems on these engines. In this cold and damp weather it's even more likely that is the problem.
Very good to know. I have an IDI like you, I haven't had to remove C.O.P.s on these engines before. Is removing the fuel rail necessary? It appears to be.
NOTE: Truck had a very poor battery and alternator, I replaced both. Could any sensors have suffered? Any guidelines on checking T.P.S. health/function?
....your customer usually start thier day off with less than a full tank of fuel? Any chance the moisture is going from the tank through the lines into the rail and/or possible that thier plugs need to be changed as well as coupled with the moisture?
Yes, very rarely has a full tank, usually around 1/4 at a time. Does the fuel rail need to be removed to get to the coil over plugs? I have heard bad things about plugs in these engines, is it a risk for me to remove them?
Looks like a nice tool. Thanks for your input everybody, I'll try these things and I will certainly post back about the results. I just don't think this will do it, but I will try.
