Regulated return???
Old May 1, 2016 | 11:17 AM
Pipedr's Avatar
Pipedr
Regulated return???
I'm on the fence about installing a regulated return on my 6.0. I am looking to increase the life of my stock injectors. What are your thoughts?
Old May 1, 2016 | 11:47 AM
TooManyToys.'s Avatar
TooManyToys.
The regulated return concept grew out of the 7.3l regarding its unique injector fuel supply issues, a noise refereed to as cackle. The 6.0L doesn't have the same head supply fault so for the 6.0L the main concern is the fuel supply pressure regulator spring fatiguing and the pressure not being regulated in the proper rate. If the spring does fatigue, the replacement blue spring replacement is the go to item to restore and supply a slight increase in provided pressure. IMO, on the 6.0L going to an aftermarket return system, dead ended or flow through, doesn't gain anything.
Monitoring the pressure to insure the system is working properly is the best thing you can modify on the fuel system side unless you have large flowing injectors, then it's a flow issue, not pressure.
tofargone
Dec 16, 2019 12:45 PM
FossenRacing
Mar 27, 2014 08:10 AM
jrmII
Aug 15, 2012 09:02 AM
vib1
Mar 28, 2012 02:16 PM
bcfordguy
Jan 22, 2008 04:53 PM
