89 F350 Dana 60
Old 04-30-2016, 10:48 PM
Nero Morg's Avatar
Nero Morg
Nero Morg is offline
89 F350 Dana 60
Hey guys, helping my old man out with his truck, currently rebuilding the front end. Literally if it moves it's getting replaced.
Just one easy question for now. Popped the diff carrier out because we need to change the inner axle tube seals, and found one of the bearings had the hard surface coming off. We intend to keep the same carrier and ring/pinion, there were no shims when it came off. Is it fair enough to say that I can simply replace the bearings on just the carrier and this will not adjust any of the end play set by the pinion or case play? The diff wasn't easy sliding out that's for sure.
Old 05-01-2016, 06:45 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
You can install it exactly the way it came out as long as you don't remove the pinion.
it's never a bad idea to check the contact patch with marking paint though, to ensure things are not worn or someone else didn't go in there and Jack everything up.
Old 05-01-2016, 07:06 AM
Nothing Special's Avatar
Nothing Special
Nothing Special is offline
I haven't had a Dana 60 apart, but if the bearings are tapered roller bearings they will be part of the axial stack-up that sets the side-to-side position of the ring gear so replacing one (or both) would require reshimming the carrier. of course you'll find out if that's necessary when you check the contact patch after reassembling it.
If it's a ball bearing it may or may not provide axial positioning, and if it's a straight roller it will likely not affect axial position.
Old 05-01-2016, 08:25 AM
Briansshop's Avatar
Briansshop
Briansshop is offline
The shims are under the the bearing,that is pressed onto the carrier. Replace the bearing with the same shim pack and it'll be fine. I'd prob check backlash just for the hell of it.
Old 05-01-2016, 09:40 AM
Nero Morg's Avatar
Nero Morg
Sweet thanks for the help, I thought those were the shims under the bearings but I couldn't quite tell. What's the easiest way to get the old bearing out? I've seen some people say press, and others say dremel til mostly cut, then punch. I want to be careful not to damage the shims.
Old 05-01-2016, 10:42 AM
Briansshop's Avatar
Briansshop
A bearing splitter and a press is the accepted way, but cutting it will work.
https://www.google.com/search?hl=en&...aring+splitter
Kyle Wood
10-21-2018 08:24 PM
PRIMERED79 SHORT BED
05-30-2018 02:42 PM
LeoJr
12-31-2013 09:30 PM
BigTiny460
03-26-2013 08:10 AM
427 fordman
12-03-2011 02:31 PM
Quick Reply: 89 F350 Dana 60
