Project loud
Old May 2, 2016 | 10:11 AM
HoustonDave's Avatar
HoustonDave
Out of a dozen responses, all but a few take a fairly disparaging view of the idea. You can get make a high-performance exhaust at much lower noise levels, probably even better for your overall performance, than straight pipes.
It's also worth noting that you freedom to be noisy only goes as far as impacting your neighbors... if you make a super-loud vehicle which bothers them, YOU become the jerk who screws up the neighborhood and liable to visits from the po-po or irate neighbors. Might be something to consider. Hate to see someone with a badge inform you that you're walking until you get the exhaust fixed.
Old May 2, 2016 | 12:06 PM
jbehuniak's Avatar
jbehuniak
Originally Posted by dixiedogford85
I have a 77 f100 with the original 302 in it I am looking for the loudest possible exhaust I can find I keep hearing glasspak is the best route any advice welcome please. Also I am wanting to bag the truck anyone done that yet?
Removing the muffler and replacing it with a glasspack will make it loud. Yes people have bagged the dentside trucks. Some fabrication, math, engineering, money, time, metal (DOM tubing and links) air compressor and bags that fit your needs will be required.
Things to think about when bagging your truck if lowering are suspension travel. Not sure which part of GA you're at but things like road construction, speed bumps (dirt roads?) will limit how far you bag the truck. If you look at the gap between your rear axle and frame you'll see there isn't too much room to drop the truck before frame modification will be required not to slam onto your bump-stops (if they're still there).
Not to bash you but having the loudest truck doesn't make it any faster. Not sure how old you are but if you're young (highschool early 20's) it doesn't make sneaking up to the girls house at midnight any fun at all. Everyone knows where you are. Its asking for a ticket. If you're leaving the local watering hole (assuming you're 21 and below .08BAC) its just asking for a field test.
With the EPA crap and everyone crying wolf about pollution you're not doing anyone any good for having a 'LOUD' truck. Look what happened to the diesel world. A few morons 'rolling coal' and now DEF is mandated for modern trucks. I may continue to rant. If you want performance save the cash put heads, cam, intake, carb on it, full tube headers some turbo mufflers and it will be loud under WOT and fine when driving normal. By making the exhaust open you are literally making the truck slower, get worse MPG, and ruining your exhaust valves. They need a certain amount of backpressure not to burn up........
davbell22602
21
Jan 10, 2012 03:03 PM
army_guy
Exhaust Systems
Jan 29, 2006 01:11 PM
hillbilly316
Exhaust Systems
Jul 28, 2005 10:36 AM
nucleartruck
Exhaust Systems
Apr 7, 2004 08:16 PM
Brad Jensen
Exhaust Systems
May 15, 2003 12:14 PM
