OIL FILTER MOUNT
Old Apr 29, 2016 | 06:14 PM
72CC428's Avatar
72CC428
OIL FILTER MOUNT
My Oil filter mount sits right over the front two inches of the lower cross member. With a Fram PH8A filter ( standard size for the FE ) there is about 1/4 inch vertical space from the bottom of the filter to the top of the cross member.
Just enough wiggle room to get the filter on and off.
Is this design brilliance? Or, another unintended consequence of my apparent mix-n-match engine?
I don't recall this being an issue when I put the 390 in my 65 F100?
Is there a shorter oil filter out there that will fit?
Old Apr 29, 2016 | 06:46 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
FE engines: The car oil filter adapter is vertical, the truck oil filter adapter is horizontal.
If the car oil filter adapter is present and the left rubber insulator breaks (somewhat common), the filter could hit the cross member splitting it open.
If you want to retain the car oil filter adapter (I assume this is what you have)...1975/78 Mustang II's with 302 used a shortened version of the FL-1A oil filter: FL-300.
Old Apr 29, 2016 | 08:33 PM
72CC428's Avatar
72CC428
So I assume you are talking about a possible motor mount failure that would cause damage to the filter?
Old Apr 29, 2016 | 08:38 PM
NumberDummy
The left engine mount breaks, the engine rears up then when comes back down...
If you have the car vertical oil filter adapter with the Motorcraft FL-1A, the filter could hit the cross member splitting it open. Not pleasant!
Old Apr 30, 2016 | 02:41 PM
72CC428's Avatar
72CC428
So I guess I'm going to order a truck one.
Could it have been that my 65's 390 sat farther forward on the mounts. One thing I remember an oldtimer showing me was just reversing the engine frame mounts when I put it in. It originally had a I6 300.
Old Apr 30, 2016 | 03:11 PM
NumberDummy
If the oil filter adapter is vertical, it's from a car. Trucks used a horizontal adapter.
Instead of replacing the car oil filter adapter, you could use the shorter oil filter (Motorcraft FL-300) I alluded to in post #2.
Old Apr 30, 2016 | 09:35 PM
72CC428's Avatar
72CC428
Yeah. Would that prevent the crush if the motor mount failed though?
Old Apr 30, 2016 | 10:50 PM
Ford_Six's Avatar
Ford_Six
4x4 trucks used the vertical oil filter mount, while 2wd used the horizontal one. Don't run a Fram filter either, they are junk. Genuine FL1As are available from WalMart for a very good price.
Old May 1, 2016 | 10:55 AM
sullyda1's Avatar
sullyda1
Shorter Oil Filter
I just use a shorter filter - Fram PH43, Bosch 3402 or equivalent from 1970 - 1980s Chrysler V8
Old May 1, 2016 | 03:35 PM
flyboy2610's Avatar
flyboy2610
When I got my truck, the oil filter on my 390 was in the vertical position and making contact with the frame crossmember. The parts man told me to use a 3/4 quart Dodge filter.
It fit perfectly and was shorter, so it has clearance from the crossmember.
Here are some filters which should work for you:
Puolator L-2081
AC PF20
Wix 51068
NAPA 1068
Fram PH43
Chrysler 3549957
Hastings LF196
Good luck.
Old May 2, 2016 | 08:05 PM
72CC428's Avatar
72CC428
Thumbs up Thank you everyone
Puolator L-2081
AC PF20
Wix 51068
NAPA 1068
Fram PH43
Chrysler 3549957
Hastings LF196
Good luck.
Thanks flyboy.
jmmartin
Feb 5, 2010 05:54 PM
Customcab
Jul 4, 2009 02:58 AM
zstyle01
Sep 6, 2007 05:59 PM
rswhitmore
Oil & Lubrication
Aug 4, 2007 02:04 AM
Customcab
Mar 21, 2007 07:33 AM
