Flickering lights
Old Apr 28, 2016 | 04:40 PM
Jarrett Campbell's Avatar
Jarrett Campbell
Flickering lights
Hey guys,
When I drive with my head lights on, they strobe from dim to bright, but only when I'm on the gas. At idle, they're always bright. Strobe frequency does not change with rpm. Any ideas what's going on?
1976 f250, 360/390 np435/np205
Old Apr 28, 2016 | 06:00 PM
Tedster9's Avatar
Tedster9
Poor grounding at regulator or failed regulator most likely.
http://www.aa1car.com/electrical.htm
http://www.aa1car.com/library/charging_checks.htm
Old Apr 28, 2016 | 10:38 PM
HIO Silver's Avatar
HIO Silver
Concur with Tedster.... that old VR may be on its last legs.
I suggest going with a solid-state version or simply swapping to a 130-amp, internally regulated 3G alternator.
Old Apr 28, 2016 | 11:00 PM
Tedster9's Avatar
Tedster9
Have battery tested too, not sure if unregulated voltage charging will have toasted a cell? Probably not, something to check, it might. The idea being, want everything on the same page after repairs - a good battery paired with a good alternator. Like Bacon and Eggs.
Spring for fresh grounding cables, to help keep resistance ultra low, where it belongs. Research shows just a few hundredths of a single ohm will cripple an alternator, 30% reduction in output. In fact that may have been what lunched the regulator in the first place.
Old Apr 29, 2016 | 09:25 AM
Jarrett Campbell
Thanks guys. I am going to have to do some research into the 3G alternator. It is always my policy to upgrade when replacing... that's how I got so deep into my powerstroke haha!!
Old Apr 29, 2016 | 09:26 AM
Jarrett Campbell
Also, thanks for the links!! I need to start learning how to work on gas engines sometime.
Old Apr 29, 2016 | 01:45 PM
HIO Silver's Avatar
HIO Silver
Visit the Tech Info Compilation linked in my signature below and use the links for the 3G alternator upgrade.
Old Apr 29, 2016 | 02:08 PM
Jarrett Campbell
I was actually just looking at that thread. Thanks HIO!
Old May 2, 2016 | 09:15 AM
Jarrett Campbell
The new VR fixed it! Thanks guys.
I will eventually get around to the 3G swap.... maybe... haha
Old May 5, 2016 | 08:29 AM
Jarrett Campbell
Ok guys.. some not so good news. I just thought my voltage gauge on the dash was bad because it was pegged in the high position after the VR swap. Finally got the multimeter to see if the gauge was correct, and in about 2 minutes of idle, voltage at the battery went from 14.7 to 16.5 V, steadily climbing. I shut it off because I knew something was still wrong and I didn't have the time to play with it.
I really don't want to just get a 3G alternator unless I have to, since this is the budget-fix truck and my powerstroke is the money pit. However, I would still like to be able to drive the old boy, so if I have to get another alternator, I'll bite the bullet.
Any ideas what would cause this? Like I said, steady climbing voltage, no bouncing up or down. Just about 1/10 of a volt every 2 seconds or so.
Old May 5, 2016 | 09:10 AM
HIO Silver's Avatar
HIO Silver
That new VR died. Reinstall the old one to verify.
Old May 5, 2016 | 09:46 AM
Jarrett Campbell
I'll check tonight. Good ole Chinese electronics
Old May 5, 2016 | 10:18 AM
ZarK-eh's Avatar
ZarK-eh
You don't necessarily need to go with the 130Amp 3g alternator, maybe consider the smaller 95Amp?
Old May 5, 2016 | 11:22 AM
Jarrett Campbell
I guess I am used to $150 alternators. I think I found one for $65 online which isn't too bad
My thing is, if I can fix it with a $15 regulator, I don't need to spend the extra $50... Upgrades will come later.
Old May 5, 2016 | 12:26 PM
mark a.'s Avatar
mark a.
Hey guys,
A bad head light switch can cause that. A bad dimmer switch can too. Reach up in the dash, if the switch is hot it is probably bad.
