Help with 7.3L IDI starting.
Old Apr 28, 2016 | 11:26 AM
Nitro Nick's Avatar
Nitro Nick
Hello I have a 1989 F250 7.3L IDI Diesel.
We have had issues with the truck starting for some time. We don't use it that much but less and less due to its starting problems. You need to crank the **** out of it to get it to start. We were doing it so much, that I needed to replace the starter and starter relay. Both burned out. I think it is a fuel supply issue, as if you give it a shot of either it fires up much quicker. Once started it runs great. I think it is not holding fuel pressure when it gets shut down and has to crank over to be primed every time.
Let me know what you guys think.
Thanks,
Old Apr 28, 2016 | 12:04 PM
Phy's Avatar
Phy
Search this forum for air intrusion, or just look at one of the many, many "hard to start" threads here...
But to answer your question, yes, it's probably losing prime.
Old Apr 28, 2016 | 05:49 PM
bashby's Avatar
bashby
After it sits a while, remove the fuel filter and see if its full to the top. If not you have an air leak. Look for damp areas around the injector return lines, at the fuel heater etc.
How about the glow pugs? Does the wts light come on for 10 or so seconds? Are you getting white smokenfrom the tailpipe while cranking?
Old Apr 28, 2016 | 08:02 PM
Leroy Unlisted's Avatar
Leroy Unlisted
Yes and until you fix the air intrusion issue prime the fuel ..
Crank 5seconds .. depress shreader valve on filter base ..
X4or5
Same procedure if u run a tank outa fuel. ..
Disconnect the small wire D side of glo plug relay to use ether safely .. i only start off ether .. but never mix glow plugs and ether at the same time ..
Alex1997
Apr 1, 2017 12:08 PM
DieselRugger
Oct 4, 2012 10:21 AM
rawandnatural
Mar 1, 2011 06:39 PM
custom1
Nov 23, 2006 08:22 AM
captainmork
Oct 14, 2006 06:32 PM
