Starting Problem 92 f250
Old Oct 12, 2006 | 12:33 PM
captainmork's Avatar
captainmork
Cool Starting Problem 92 f250
I am having trouble starting my 1992 f250 Have changed glow plugs, compressor pump, batteries, plug wires. etc. etc.!! and everything suggested by several diesel shops with no luck. It will start after plugging in for about 15 minutes instantly. Once started, it will start again all day instantly. Obviously missing something any ideas????
Thanks for any info. or ideas Mark
Old Oct 12, 2006 | 05:31 PM
PLC7.3's Avatar
PLC7.3
Air in the fuel system........fuel drains off and you have to re prime it in the mornings.
How old are the fuel injector return lines....... are they grey in color. after doing that much work on the engine for sure the return lines and caps were disturbed......old ones disturbed leak like sieves........
You could do the clear line test, remove the return line to the filter header at #1 injector and replace it with a clear fuel line with a large pigtail. Do the same from the IP to #2 injector, what your looking for is air after shutdown and which way it is moving. Drive the truck like this for a while at highway speeds to remove any residual air in the system.
Also try the .........
Do a pressure and flow test of the fuel pump at the Schrader valve on the filter header (FSS- fuel shutoff solenoid disconnected on IP). Remove the tire valve core and hook a hose and pressure guage on it should see 4-6 psi when cranking. Then do a fuel quantity test same place, should see 1/3 pint in 10 seconds of engine cranking, route fuel to a suitable container with a hose.
Old Oct 12, 2006 | 06:47 PM
Hamberger's Avatar
Hamberger
That is a tough one. If she starts right up when you plug her in then it is unlikely to be an air intrusion problem as you would still have starting difficulties.
How old is your starter? Older starters tend to slow down and during cold starting just don't produce enough compression to fire the engine. If you plug the truck in and warm up the motor (or do a warm start) the engine has less resistance and the old starter still gets it started.
I had two friends who both solved their cold starting problems by replacing their aging starters. (Both had about 150,000 miles on their starters)
Hope this helps a little,
Seb....
Old Oct 12, 2006 | 07:10 PM
Agemenon's Avatar
Agemenon
You could also have a problem with your glow plug relay. How long does your light come on for? Are you hearing the "clicks" coming from underneath the hood? If you don't hear anything, your GP relay is scrapped and you need to get a new one put on. If this isn't working, it's not sending any current to your glow plugs...therefore, the combustion chambers aren't being heated. And I agree with what Hamberger said about the engine having less resistance to start if it's warm. I too don't think it's an air intrusion problem in your lines. Best thing to do is to get your starter and glow plug relay checked out.
Also, do you use your truck all day? Or are you just doing the typical drive to work in the morning and drive back home at night? If you're running your truck all day, it would make sense that it's easier to start because the engine is still hot from the last time you ran it.
Old Oct 12, 2006 | 11:18 PM
KJLYPW's Avatar
KJLYPW
I would concure with the slow starter when cold problem, Mine with about 150K miles was slowing down, difficult to start. As the brushes in the starter wear down to a certain point, the springs no longer can put enough pressure on brush to armature contact for proper current flow. I installed new brushes cleaned it up, and is working like new again.
Old Oct 13, 2006 | 03:05 PM
captainmork
Thanks for the info. but I had the relay changed too! The light stays on for about 3 seconds when warm and maybe about 6 to 8 when cold. The starter was checked and OK I agree its not a fuel problem(would do the same hot or cold) It is getting fuel when cranking cause smoke will come out when cranking to long. Thanks again for any other ideas!!
Allmost stumped..........Mark
Old Oct 13, 2006 | 03:40 PM
bilder12's Avatar
bilder12
see if the starter is pulling lots of power when cranking ... sounds like you have cooked it if you have put it thru long periods of cranking without letting it cool down. The starters are susceptible to damage after cranking too long ... usually 20 seconds and 2 minute cooldown time works.
Old Oct 13, 2006 | 04:58 PM
PLC7.3's Avatar
PLC7.3
The engine/starter is required to turn faster when starting hot........
Old Oct 13, 2006 | 07:12 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
HAve you checked the power comming off the relay. See if you loose power to the glow plugs.
Old Oct 13, 2006 | 08:36 PM
captainmork
Starting Problem????
Seb....
I really appreciate all the help guy's!!! But I really don't think plugging it in for 10 minutes(then it starts) really has anything to do with the starter do you? I may be wrong but, had the starter checked and it's OK. I really don't want to buy a new one, as this trial and error thing is getting quite costly(especially at the shops) Once again I really appreciate all the info. from you guy's!!!!
Thanks again Mark
Old Oct 13, 2006 | 08:47 PM
bigredtruckmi
Veteran: Navy
Ok lets re-evaluate what we've got.
first - no start unless plugged in for 15 minutes
second - changed glow plugs, relay
third- getting white smoke
I am wondering if the new relay is bad or doesn't have a good ground. take relay off motor and add a wire from battery (-) to the ground for the relay (this will be the wire going to a bolt which attaches the relay to engine) I've had a bad ground here and wouldn't start.
Old Oct 14, 2006 | 06:32 PM
captainmork
Thqnks
Will try tommorro and let you know the outcome.......thanks again!!!!
tarheel007
18
Mar 5, 2024 12:40 PM
406angler
Dec 20, 2014 10:34 PM
moparsbetter
Oct 11, 2014 06:15 PM
tulleydr
Dec 18, 2011 05:04 PM
slpin
1978 - 1996 Big Bronco
Sep 29, 2006 10:14 PM
