TFT and EOT Difference help
Old Apr 29, 2016 | 06:59 AM
lhud's Avatar
lhud
During say 80 deg. days and after the engine has warmed up the TFT will be approximately twice the ambient temperature as seen on the overhead indicator. The EOT will then run approximately 35 deg. to 50 deg. (depending on ambient temps) higher than TFT. Remember, these are not exact numbers but good ball park numbers.
Old Apr 29, 2016 | 07:25 AM
Tugly's Avatar
Tugly
Originally Posted by Mark Kovalsky
Nope. You've described torque converter slip. Transmission slip is measured by turbine speed (TSS) and output speed (OSS.)....
Crap. You caught me before my coffee kicked in. Thank you for the correction, I amended my post to match your information. Without the coffee, my senior moments are frequent.
Old Apr 29, 2016 | 07:32 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by Otto396
I checked this on my way home and noticed transmission slip is within a very small amount when in 3rd gear but as soon as I shift into OD the difference becomes huge. Almost double. I assume this is due to gearing?
No, I think that's due to bad calculations on whatever you're looking at for this information. Unless the transmission has failed transmission slip will always be well below 10 RPM. And that's just noise, in reality there is no slip inside a transmission when a shift is not occurring.
The torque converter does slip, and slips a lot when it isn't locked.
Old Apr 29, 2016 | 07:51 AM
Tugly's Avatar
Tugly
My TC slip reads under 10 in 3rd gear and OD. If I press the OD cancel button... the TCLU drops out and I'm slipping again, but the TCLU re-engages if I press the throttle and my TC slip drops back down to under 10 at the higher RPMs.
Old Apr 29, 2016 | 09:55 AM
Otto396's Avatar
Otto396
My torque converter locks around 35 MPH and stays locked. The only time it disengages is if I am in OD and I drop below 40. Then it will let go. If I disengage OD manually though the TC stays locked and disengages just below 30MPH. I was told I have a factory tow thing from the fella I bought the truck from. The transmission won't shift into OD until I hit 55 OR I press the OD button on the column. Otherwise I can rev the **** out of it and she stays in 3rd.
Old Apr 29, 2016 | 09:57 AM
Otto396's Avatar
Otto396
I'm looking at my nDash from Jody. It reads from the OBD Port. I have a large discrepancy on those numbers until I have TCLU around 35MPH
UGA33
Sep 30, 2017 08:30 AM
majorgator
Apr 3, 2015 09:21 PM
Lloydable
Nov 17, 2010 04:46 PM
messeswithtrux
20
Apr 23, 2008 05:45 PM
tommyl
34
Aug 8, 2007 07:38 AM
