I don't even know what USB2 means... All I know is that the system seems to work fine with my iPhone-6 for playing Pandora over bluetooth and the phone functions fine for calling. I have not tried texting with it though.
I think I will just leave it alone then...
With this latest update, USB2 'technically' no longer exists, and lots of times if I'm on USB and shut off the truck, when I start it back up it is on AM. Not thrilled I did this update.
Not sure which version you have, although one of the improvements version 4.4 is supposed to correct is the problem you're having.
"Previous USB or Bluetooth media source playback now resumed after ignition cycle."
LOL DON'T DO IT MINE IS SO F UP NOW DEALER CANT EVEN FIGURE OUT WHAT TO DO . no phone no usb and just some times Bluetooth audio after she tells me Bluetooth Bluetooth 2 times . oh my god to have my 2009 sync never one issue lol so much for the new things
For those of you with 2012-2013 model year trucks having issues with SYNC, Bluetooth and phone pairing/connectivity there is an update for the Accessory Protocol Interface Module (APIM). This should correct your issues. I have corrected two trucks having these problems and to the best of my knowledge it has never created any issues. But please understand, the update is to correct the software. If you are experiencing problems it would be in your best interest to have a dealer technician check the system for codes other than DTC U3000:04 in the APIM that would indicate other system faults that are affecting your SYNC functionality that a software update is not going to correct. My opinion on software updates is that no matter what model year vehicle you have, it is best to be up to date regardless but if everything is working perfectly for you and you are happy happy with it then leaving it alone is fine too. There are a couple of service bulletins addressing SYNC concerns with explicit instructions that also refer the technician to the software update instructions in the workshop manual using IDS. If your dealer is confused, ask them to run the appropriate symptom codes on OASIS and go from there.
if i were you i would wait and see what happens at least yours works some times. I called ford no way to go back so now until a new radio i have nothing 3 weeks back order what does that tell you 2016 f 350 56 thousand and i get told sorry lol thanks
ps make sure you get a new radio they try to give you a used radio and then sat radio has issues first replacement radio was from 2013 f 150 could not get it register with sirius xm lol
