Serial Number Help
Old Apr 27, 2016 | 09:21 AM
fancyvern's Avatar
fancyvern
Serial Number Help
I have a serial no. for a Ford Panel truck. I know this is not the correct place to look but I did not see a panel section. I hope someone can help me break this down, if not direct me to the correct place. P5D2HM14733 is the serial no. Thanks
Old Apr 27, 2016 | 01:06 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by fancyvern
I have a VIN for a Ford P Series Parcel Delivery: P5D2HM14733
The VIN is what your truck is registered by, but you typed this number wrong.
The 1st 3 digits are P50 = P500 Parcel Delivery.
The 4th digit of 2 decodes to a 6 cylinder Detroit 6-71 diesel, is this the engine your truck has?
The 5th digit of H decodes to the Lorain OH Assembly Plant.
The last 6 digits of the VIN is the serial number: M14733 = 1971.
Type further questions in the LARGE TRUCK forum.
Old Apr 27, 2016 | 09:35 PM
fancyvern's Avatar
fancyvern
V. I. N. Number
The serial number is right. The Trans. is 3HD. The rear axle is 5.83. The color is P. The production code is 6BNY102. The W. B. is 134. The Cert. H. P. is 91 at 3400 R.P.M. Max. G.V.W. is 14000. The DSO is 21857. I took all of this off of the ID plate on the dash. With all of this I still do not know what year it is! It looks like a one to one and a half ton set up. It has three on the tree shifter. The engine would have to be a little 6cyl. by looking at the small grille and short engine compartment.
Old Apr 28, 2016 | 12:34 PM
NumberDummy
The serial number is the last 6 digits of the VIN: M14633 = 1971.
The two 6 cylinder engines installed in these P series trucks were 240 I-6 (VIN engine code, 4th digit A) & 300 I-6 (VIN engine code, 4th digit B).
P series: Ford supplied the rolling chassis and front sheet metal, the body was installed after the truck left the assembly line.
3Bushwackers
Large Truck
Aug 7, 2017 06:55 AM
burnhedge
Jan 22, 2015 03:43 PM
Billy Miller
Large Truck
Oct 18, 2012 01:13 AM
MANSON
Large Truck
Oct 26, 2010 11:54 AM
2bocat
Jan 15, 2006 12:18 PM
