Going to cut off all the unnecessary angle iron and probably the headache board to make it prettier
Found a lot of loose stuff, not sure why but the steering box was so loose it was moving fore and aft 1/8" so I thought it was bad. Turns out it wasn't bolted to the frame but finger tight...
Right front bearing isn't seated either? Don't know if someone started servicing them and forgot to tighten, but there had to be 30years of gunk on the bolts so ...
First things first, the head is cracked from freezing at some point-could have been him, could have been me who forgot to change the water out??
Jordon sent me a head to replace the cracked one- fluxed and decked .060" ($260 later -ouch) I guess it was pretty warped, but no cracks
Be sure to check clearance, valves and pistons to head. Good looking project truck and an F4 at that.
