1948 F-4. Driver build
#61
Well wouldn't the one thing I didn't go through, nor feel like going thru l ***** the bed ...
Saw some clutch spring remnants in the housing when I pulled the starter, so I investigated down the inspection hole. Found another one in the bottom and looks like only one spring left in the clutch
Throw out fork was askew on the throw out bearing too. I yanked it in place but now it doesn't fully retract so now it won't engage the clutch on the flywheel and the truck won't move...
Oh well time to yank the crashbox and put in the synchromesh
#62
#65
#67
Does the '60 have a single or double bend?
My '63 has a double bend and would definitely hit
#69
Need to do the same with my PTO shaft
I need a 3/4x3/4 u-joint for it too, the T9 had a 1" PTO shaft, Heli one has a 3/4"
I also have to modify the dump valve rod but that's easy, PO had the lever right in the middle of the pass floor ... Worked ok but a pain to sit there with it under passenger's knee
#72
Mark
Every one I've taken out of a 48-52 has been this one..matter of fact didn't feel like cleaning the one that came out, this ones from an F-6 I took apart and rebuild a couple years back.
Is yours perhaps like in the 53 & later? They're normally stamped and not cast with a bigger donut
#74
Ha!
I'm reserving my brownie for my F-5 MH
I took the 5.83 out of this F-4 to put into that one...put the 2- speed in from that one to make this an F-5
I have to go pick up the other 5.83 R&P for the front axle its sitting out in the woods now
That project is next unless the Napco goes next
